Learning - Gear Linkage Cable Failed Due To Bad Placement
7 replies to this topic
#1 swast4
swast4
  • 416 posts
  • Interests:Trackdays
Posted 21 January 2020 - 09:00 PM
Hi,
Thought I'd share a learning with you regarding my gear linkage cables. A couple of track days ago, I came in off a session and it felt like the car was still in gear even though it was in neutral. The next time I took car out and put it in the trailer, it kept popping out of 1st.
I managed to do my next track day but something wasn't right.
I was hoping it wasn't my box, so I bought some new fully synthetic oil and hoped for the best. Then when doing the oil change today I did a bit more googling and found that the gear linkage cables could be issue, so I popped off the cables on the gearbox end and found the forward back motion was still stiff. Bingo, I am really pleased it's not my box but it has cost me £225 on a new cable and probably a pain to fit.
The learning here is that the cable must have been right next to the downpipe of the exhaust and this could have been avoided if I moved it away from this pipe. The exaust has been off a few times and New brace bar fitted, so I must have nudged it towards the exhaust pipe.
So next time you're under the car, please make sure it is away from this pipe and maybe strap it away. I hope this helps.
AdamPosted Image
Sent from my F1 using Tapatalk
#2 OneYet
OneYet
  • 1,355 posts
Posted 22 January 2020 - 02:53 PM
True!
I also bought some pipe-type heatshielding to put on the cables and being paranoid about having to swap the cables again I also manufactured a small aluminium heatshield that bolts to the engine mount.
#3 swast4
swast4
  • 416 posts
Posted 22 January 2020 - 03:11 PM
Good idea, is it a ball ache to change the cables ? Elise-shop ones
#4 FLD
Posted 22 January 2020 - 03:26 PM
My car has a hook for the gear cables that stops them getting close to the exhaust.  It's fitted on the heat shield bolt
#5 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 22 January 2020 - 03:29 PM
If anyone needs cables I have a good used set.
#6 smiley
Posted 22 January 2020 - 04:41 PM
Can i have them foxy?
If they are na.
#7 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 22 January 2020 - 06:02 PM
If they are na.
Sure, but Partridge told me they weren't model specific. They're from a VXR. I'll send pics if you like
Edit - Partridge was wrong. VXT/R ones are longer!
#8 smiley
Posted 22 January 2020 - 06:31 PM
No turbo for me foxy.
Way to fast for this old man.
