Diy Super Charger Fit
Posted 22 March 2020 - 12:40 PM
Working my way through a diy supercharger fit ( Yey ) i May need a little advice as I work my way through it if anyone is experienced in this
My first question is the alternator, I have bought what I believe is a 100 amp one but it’s still to big can anyone point me in the right direction mine is 180mm over all is this right as seems to be about 5mm plus to long as hitting manifold
Second question is why do I need a suppresssor and if so which one lol
Posted 22 March 2020 - 12:57 PM
Even with the 100A alternator you have to trim the rear end down
Posted 22 March 2020 - 01:48 PM
Hi so remove some of the plastic then ?
Posted 22 March 2020 - 02:05 PM
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Posted 22 March 2020 - 02:10 PM
There are 2 differend 100a alternator, 180mm is thé good one. You have to remove te plastic kap (bleu cicle) and shorten thé bolt (red circle)
Oh is it ok then to run with out the cap that’s why I’m struggling as trying to retain the cap but cutting away
Posted 22 March 2020 - 05:15 PM
You can modify the plastic cap and so keep the internal surpressor. There are some pics here on the forum.
Posted 22 March 2020 - 07:55 PM
Posted 23 March 2020 - 07:55 AM
best to disconnect battery during the process
Posted 23 March 2020 - 08:20 AM
Posted 23 March 2020 - 09:02 AM
Posted 23 March 2020 - 05:15 PM
100A alternator with the modified plastic cover (includes surpressor) and the shortened connection thread:
