Annoying Noise
11 replies to this topic
#1 kpf1grandprix
kpf1grandprix
  • 151 posts
Posted 27 March 2020 - 11:02 PM
Hi I’ve got this drumming type rattle noise towards the front of car beneath the clam ,that goes away once warmed up ,any ideas what it could be
#2 smiley
Posted 28 March 2020 - 02:37 AM
Does the speed of the rattle sound go up with increased speed of the car?
Is it gone as soon as you press the brakes?
Edited by smiley, 28 March 2020 - 02:38 AM.
#3 kpf1grandprix
kpf1grandprix
  • 151 posts
Posted 28 March 2020 - 09:28 AM
No at standstill. By the time I drive off it’s warmed up enough to disappear.
The noise tends to travel along the whole car while I’m standing there. Was thinking maybe the under trays
If I raise the revs it resonates then vanishes
#4 coldel
coldel
  • 1,183 posts
Posted 28 March 2020 - 09:59 AM
Maybe try video it? Can you post you tube links on here can’t remember
#5 kpf1grandprix
kpf1grandprix
  • 151 posts
Posted 28 March 2020 - 10:20 AM
Ah maybe put a vid on the VX220 Facebook , that’s pretty easy to do
#6 smiley
Posted 28 March 2020 - 10:49 AM
With your "one warmed up", my guess would be crack in the exhaust manifold.
Creates a tipical ticking sound at startup, that goes away once hot (30 sec to a min), when sealing the crack.
Edited by smiley, 28 March 2020 - 10:54 AM.
#7 OneYet
OneYet
  • 1,355 posts
Posted 28 March 2020 - 11:32 AM
Do you mean at the front of the car or towards the front in the engine bay?
#8 myles
myles
    Sausagefest
  • 2,093 posts
Posted 28 March 2020 - 11:50 AM
Yeah I'm there with my Piper manifold, it's literally a cracking upgrade.
#9 chris_uk
Posted 28 March 2020 - 12:53 PM
a cracked manifold does tick until its warm enough for the metal to expand and seal the crack.. they usually crack between primaries 2 & 3.
#10 kpf1grandprix
kpf1grandprix
  • 151 posts
Posted 28 March 2020 - 03:44 PM
Yes mate front of the car. Not engine. But the vibration noise travels along car to back. Had a look yesterday and if I apply my weight onto rad it quietens
#11 ayresyy
ayresyy
  • 490 posts
Posted 30 March 2020 - 10:59 AM
Maybe one of the coolant hoses is slightly loose in the sill?
#12 2-20
2-20
  • 1,317 posts
Posted 30 March 2020 - 11:36 AM
You should check radiator fasteners and fan...
Something is getting loose... Dilatation coming from radiators heat may be a reason for disappearing when warm.
