Preventative Jobs To Do.....
Posted 17 April 2020 - 09:56 PM
Posted 18 April 2020 - 09:17 AM
Posted 18 April 2020 - 10:40 AM
Radiator, oil service. Fit a new hubring with the ABS wires before the useless effin things snap.
Posted 18 April 2020 - 05:42 PM
Gearbox oil?
Posted 18 April 2020 - 11:13 PM
Side engine mounts replace, poly inserts front and read, timing chain (water pump while you're in there). At the front replace the fog light bulbs, if you're planning on upgrading the heater might as well do it now too. Plus, radiator pipes if you're replacing the radiator. Silicone ones are a good shout.
If you fancy playing, then balancer shaft delete, braided brake hoses etc
All these jobs are possible with the clams on, just easier with them off. A couple of the ones mentioned above can only be done with the clams off
Supercharger
Edited by TheRealVXed, 18 April 2020 - 11:16 PM.
Posted 19 April 2020 - 02:12 PM
check rear brake lines in sills that corrode.
Posted 19 April 2020 - 02:47 PM
Posted 19 April 2020 - 06:16 PM
I’ve got a water pump and all the service bits on their way, steering rack is out for refurb along with new UJs, and I’ll check the brake lines though I think they’ve been done.
Supercharger.......... yeeeeeessss, it’ll have to wait though.....
Posted 19 April 2020 - 06:24 PM
weeeeee
Posted 19 April 2020 - 08:13 PM
Front tow bracket replace while the clam is off
i'm in the middle of making a nice uprated one atm complete with post and toe eye as a kit.
Posted 26 April 2020 - 09:52 PM
A mate of mine is making me a towing eye bracket already - mine was nasty! I’m also tidying up the cobbled up inlet pipe work and changing the rear brake pipes as they’re a bit crusty, oh and giving it a full respray while everything is off.
Inside I’ve got dynamat ready to go on the floor and bulkheads, new steering UJs, DAB radio and speakers.
Has anyone got any recommendations on what to use for a new exhaust heat shield? I’ve been looking at the zircoflex sheet - would that suit?
Posted 26 April 2020 - 10:08 PM
I've used Nimbus before and seems similar to OE material.
Posted 08 July 2020 - 08:49 PM
I’ve ordered an EP ultimate rack and a 48l tank to complete the chassis but I’m wondering about engine mods. I’m trying to keep it relatively standard mechanically - I’ve done the 500hp thing and (I hate to say this) but Ive realised I get more pleasure wringing the VX’s neck. My thinking is balance shaft delete and TTV lightweight flywheel and leave it at that. Any thoughts?
Posted 08 July 2020 - 11:02 PM
It transforms the cars pace but the character of the engine is exactly the same. Just feels like the 2.2 is more like 3.2 and provided you stick to the 250-260 mark it won't keep breaking ancillaries.
More than happy to show you mine near swansea when things get more normal.
I find on track it's relative, the hot hatches that can were matching your NA for striaight line pace become the 911s etc, but on the road I feel the benefits even more so. The in gear pull from any revs is excellent.
Posted 08 July 2020 - 11:27 PM
I’ve completed all the suggested jobs so thanks for the suggestions, however the bodywork repairs have been so extensive I’ve decided on keeping the car off the road for another year and doing some more jobs......
tbh, its a pretty good idea ..
if you need a TTV Flywheel just drop me a message
Posted 08 July 2020 - 11:40 PM
i got balancer shaft delete kit and ttv flywheel on the shelf if you need it..
also got 3 sc kits
Posted 09 July 2020 - 07:35 AM
