Removable Steering Wheel Kit
4 replies to this topic
#1 ChrisO_VX
ChrisO_VX
  • 62 posts
Posted 03 May 2020 - 06:58 AM
Have I lost my mind when ordering this; https://www.elisepar...ring-wheel-kit/
... to fit the original wheel?  I ordered the airbag / 40mm spacer options.  The intention was to A; bring the wheel closer to me B; use it as a boss kit at a later date when I could afford a new wheel and C; I just thought it seemed cool to be able to remove the wheel :tumble:
Was twisting over it when I thought it 'only' cost £189.  After adding the options + VAT the £264 I've spent may have given me the first sense of buyers remorse I've felt in decades
#2 Ivor
Ivor
  • 2,219 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 03 May 2020 - 07:50 AM
Cheap anti theft device
#3 paul_mck
paul_mck
  • 284 posts
Posted 03 May 2020 - 06:25 PM
I asked would it work with oem wheel and was told no. Cant see there being airbag connections
#4 Arno
Arno
  • 1,238 posts
Posted 04 May 2020 - 06:16 AM
Yup..  You can fit this, but you'll have to disconnect the airbag. Only the horn will be passed through..
Lotus has a foam center piece as a replacement for the MOMO wheel used in Cup cars that don't come with the airbags.
Also you dont' really want to dis- and reconnect the airbag every time. There's a tiny, but non-zero, chance it will get triggered, so a quick-release is usually a no-no with an airbag.
#5 paul_mck
paul_mck
  • 284 posts
Posted 04 May 2020 - 06:50 AM
I use their 30mm spacer on my oem wheel. EP said it wasn’t for oem wheels but it works ok with a few tweaks. The oem wires just about extend enough to connect to the airbag without modification
