Replacement Wheel Bolts
7 replies to this topic
#1 furtive
furtive
  • 1,134 posts
Posted 04 June 2020 - 09:40 AM
I need to replace my wheel bolts. Any reason not to get these:
https://www.elisepar...s3-wheel-bolts/
Do I also need the thin-walled socket they flog to go with them?
Are there alternate bolts I should consider or are bolts bolts?
#2 coldel
coldel
  • 1,183 posts
Posted 04 June 2020 - 09:43 AM
Where I can I go for internal drive bolts/nuts for wheels - if you do have to get external drive I would advise getting a nylon sleeve for the socket so it doesn't scratch the wheels if it comes into contact with them.
#3 hairy
hairy
    Moonlander
  • 6,063 posts
Posted 04 June 2020 - 12:03 PM
They look alright to me. Normal bolts are 17mm and don't need a thin walled socket so I can't see why these would.
#4 paul_mck
paul_mck
  • 284 posts
Posted 04 June 2020 - 12:18 PM
I have 19mm nuts on my stud conversion and a socket with sleeve works ok (OEM wheels) but its very tight
#5 furtive
furtive
  • 1,134 posts
Posted 04 June 2020 - 12:40 PM
Great, thanks
#6 furtive
furtive
  • 1,134 posts
Posted 04 June 2020 - 02:33 PM
Like these you mean? Is the internal spline so you don't scratch the wheels, or is there any other reason for it?
https://www.seriousl...el-bolt-kit-352
Edited by furtive, 04 June 2020 - 02:34 PM.
#7 coldel
coldel
  • 1,183 posts
Posted 04 June 2020 - 03:08 PM
Yeah something like that. No chance of any rounding off, won’t touch wheels, and by not having to touch the outside of the nuts wont end up taking any paint off them I.e. they stay looking pretty!
#8 furtive
furtive
  • 1,134 posts
Posted 04 June 2020 - 04:09 PM
I've ordered a set
