Ecu Fail
38 replies to this topic
#21 Braus
Braus
  • 36 posts
Posted 10 June 2020 - 12:56 AM
Standard ECUs don't like standing and I've had two not recover from standing idle for a period.  One may have been a bad pedal, but other other was certain ECU.  Speak to Liam at MMG he was a critical link in the resolution of both problems.  The solution was a three part set from Ebay, ECU, key chip and sensor.
#22 Braus
Braus
  • 36 posts
Posted 10 June 2020 - 01:10 AM
Ahh, that could be the reason it failed as it sat for a long period as it wouldn't start. The local GM dealership was useless - they said the only solution was an after market ECU, then a good mate found that the ECU and immobiliser were not communicating and got it running using Opcom.
#23 Braus
Braus
  • 36 posts
Posted 10 June 2020 - 01:38 AM
  I would suggest ruling out all other possible issues first, as mentioned. Then, absolute worst case, the ECU 'could' have a failed injector driver (hugely rare as others have said). You can still lift your current map from the ECU, then buy a cheap replacement from a 1.2 Corsa C (Holden Barina circa 2002) for around £30, they are so cheap as they so rarely fail! Then just drop your map onto the New ECU and off you go again.
#24 Braus
Braus
  • 36 posts
Posted 10 June 2020 - 01:42 AM
Ayresyy, how do I go about lifting the current map from the old ECU and dropping it onto a new one?
Thanks mate : )
#25 Cavturbo
Cavturbo
  • 388 posts
Posted 10 June 2020 - 04:11 AM
http://www.vx220.org...e/?fromsearch=1
Not sure if the above may assist
#26 aquilaproejct
aquilaproejct
  • 267 posts
Posted 10 June 2020 - 08:11 AM
Hey Mate,
All Holden dealers were given access to the Opel side as well... Not Vauxhall, but Opel. Using an MDI they will be able to program.
#27 ayresyy
ayresyy
  • 490 posts
Posted 10 June 2020 - 01:27 PM
Thanks mate : )
The map can be read/wrote using Kess or Galletto etc, and op-com/Vaux-com or Tech2 will install the ECU as long as you get one that has been divorced from the donor car.
#28 Braus
Braus
  • 36 posts
Posted 11 June 2020 - 03:57 AM
Pardon my ignorance Ayresyy, what is the method for divorcing an ECU from the donor car? Also, can the entire process be done with Windows 10?
#29 Braus
Braus
  • 36 posts
Posted 11 June 2020 - 04:09 AM
aquilaproejct
Anth - thanks for that...Could be why the local dealership couldn't do it- confusing Vauxhall for Opel?
#30 ayresyy
ayresyy
  • 490 posts
Posted 11 June 2020 - 07:21 AM
   As long as you have the correct software and bits of hardware, it is all possible through a windows 10 machine (that's how I have done it in ther past). You can use Op-com or Tech2 to divorce the replacement ECU (basically uninstall it and unlock the immo code) from the donor car, or just buy one that's been done already. Failing that, a lot of ECU's can be force unlocked once on the car using carprog or something similar.
#31 aquilaproejct
aquilaproejct
  • 267 posts
Posted 11 June 2020 - 09:17 AM
Opcom can unlock an ECU out of the donor car in a new car..tech 2 cannot do this, unless you divorce all modules, which might get hairy.. The catch may be is that you need a vx220 ECU. This is true for NA. And I presume for turbo. While the hardware ecu between a vx220 and an astra for example is the same, the software is not. You need a dealer to reprogram it through mdi to avoid various MIL .. a tech 2 cannot do this unless you have the Opel/Vauxhall cartridge in it. Tech 2 can only set configurations.
#32 ayresyy
ayresyy
  • 490 posts
Posted 11 June 2020 - 01:31 PM
[quote name="aquilaproejct" post="1988552" timestamp="1591867021"]
Opcom can unlock an ECU out of the donor car in a new car..tech 2 cannot do this, unless you divorce all modules, which might get hairy.. The catch may be is that you need a vx220 ECU. This is true for NA. And I presume for turbo. While the hardware ecu between a vx220 and an astra for example is the same, the software is not. You need a dealer to reprogram it through mdi to avoid various MIL .. a tech 2 cannot do this unless you have the Opel/Vauxhall cartridge in it. Tech 2 can only set configurations.[/quote
That’s the reason you need to install a full bin read onto the new ECU from your original ECU. Once you have this file you can flash it onto the vx/Astra/corsa ECU it becomes a clone of your original ECU. There shouldn’t be any need to use a VX220 ECU specifically if we are referring to a turbo, as long as it’s the correct ECU. I have a 1.2 corsa ECU on my turbo and it’s been fine for years now.
#33 aquilaproejct
aquilaproejct
  • 267 posts
Posted 11 June 2020 - 09:49 PM
Correct.
Same hardware as other Opels.
Different software.
Get the right software on. No Mil light.
Wrong software. Mil light
#34 Braus
Braus
  • 36 posts
Posted 13 June 2020 - 12:16 AM
Thank you for your helpful advice guys. It's a bit beyond my technical ability but
good to know there are options :)
#35 blackoctagon
blackoctagon
  • 213 posts
Posted 13 June 2020 - 05:49 PM
I use a MPPS cable and software for mine. Ebay will provide.
The internet has a number of guides to get the .BIN from a Z22se ECU, but I can put up a step-by-step if you are not too confident, or are troubled seeing done in a car that is not a VX220.
It sounds 1000 times scarier than it actually is. I know some people who I would not trust to tie their own sholeaces use it happily.
#36 Braus
Braus
  • 36 posts
Posted 14 June 2020 - 12:52 AM
Thanks Blackoctagon - a step by step guide would be appreciated in case we have to go that way, plus it may be helpful to others in the same situation.
Cheers :)
#37 Braus
Braus
  • 36 posts
Posted 14 June 2020 - 12:55 AM
Bit of a long shot but does anyone have a genuine turbo ECU from a wrecked car for sale please?
#38 blackoctagon
blackoctagon
  • 213 posts
Posted 16 June 2020 - 09:44 AM
Braus,
I'll put one up in the next day or two.
If you don't mind i'll put it in a fresh thread so it can be more easily searched in the future, but i'll put the link in this thread.
Edited by blackoctagon, 16 June 2020 - 09:45 AM.
#39 Braus
Braus
  • 36 posts
Posted 16 June 2020 - 09:17 PM
That's a very good idea - thank you!
