Mounting Ep Harness Bar In Vxt
4 replies to this topic
#1 Joon
Joon
  • 10 posts
Posted 01 July 2020 - 02:19 PM
Does anyone have any pictures showing how the bar end's are intended to be mounted to the rollbar. I just do not seem to get it right!
#2 smiley
Posted 01 July 2020 - 02:38 PM
Did you take the seats out first?
#3 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 02 July 2020 - 02:20 PM
didn't honestly think it was that difficult to work out.. wasn't it only 2 bolts then 2 more drilled.?
#4 smiley
Posted 02 July 2020 - 03:34 PM
Based on the pictures from the EP website, i woud guess it only uses the 2 existing bolts in the rollbar.
Can you show us a picture of what your struggeling with Joon?
#5 Joon
Joon
  • 10 posts
Posted 31 July 2020 - 10:26 AM
Sorry for late response due to vacation. My seats are out and harness detached. I have not found any instructions how to mount this bar but as of now i have interpreted the mounting orderin this way. Reuse the harness steel distance and place it between rollbar and harness bar then the harness bar a new steel washer then harness swivelpoint and lastly the bolt through it all. Too me this could work, the harness bar will probably rotate some 30-45 degrees if the 4/6p harness pull fwd in a crash. This since the mounting is off center from the bar. I have not seen any instruction of additional fastners and drilling in the roll bar do not seem vise.
