Aux / Alternator Belt And Pulley Question...
5 replies to this topic
#1 rossd0131
rossd0131
  • 21 posts
Posted 02 July 2020 - 09:22 AM
Morning Folks,
I've tried to Google, search the forums, and asked on the Facebook group but as yet can't find the answer...
Question for the experts out there...
I recently purchased a 35k mileage VX220 turbo and decided to replace the alternator/auxiliary belt. The old belt appeared in good order with no tears or damage and I quickly removed it without any fuss... But, when fitting the new one I noticed that the belt has 5 ribs, but the guide pulley (which sits where the aircon would be) has 6 grooves... so, should the belt sit on the inner 5 grooves (closer to the cambelt cover) or the outer 5 grooves (closest to the wheel arch)... or do I have the wrong parts 🤔
#2 ayresyy
ayresyy
  • 490 posts
Posted 02 July 2020 - 01:26 PM
I’m fairly sure there is only meant to be 5 grooves in the original alternator pulley to fit the 5PK belt. Maybe yours has been changed at some point?
#3 hairy
hairy
    Moonlander
  • 6,063 posts
Posted 02 July 2020 - 01:29 PM
I would say 5 grooves too.
#4 rossd0131
rossd0131
  • 21 posts
Posted 02 July 2020 - 09:10 PM
Thanks guys. I phoned vauhall, they didn't have the OE part in stock but they gave me the part number and I ran it through Google... all the results show me 6 groove pulleys.
Is anyone with a turbo able to have a look at their car if its not too much trouble?
#5 scw02102
scw02102
  • 1,581 posts
Posted 06 July 2020 - 03:55 PM
Just checked for you and the turbo defiantly has 5 ribs and NOT 6
#6 rossd0131
rossd0131
  • 21 posts
Posted 09 July 2020 - 10:59 AM
Thanks. Do you mean 5 ribs on the belt? That is what I have and is consistent with all the searches I have done.
My original pulley had 6 grooves but I removed the old belt without keeping a record of where it sat. I have been sent a picture by another member who had the same on his car. He took a photo of the belt placement prior to the change and the belt was mounted on the outer 5 grooves - i.e. the groove nearest the engine was empty.
I ordered a new OE Gates Pulley and it arrived today. It also has 6 grooves and I am going to fit it as described above.
Hopefully this info will be useful is anyone else notices the same issue when changing their aux belt.
