Ongoing Problem
Posted 03 July 2020 - 04:40 PM
Been trying to get to the end of an ongoing problem with the vx220 n/a starts ticks over runs fine until temperature reaches above 90 then just cuts out restarts within seconds thought it was temperature sensor changed didnt change anything advice was possible crank sensor or egr both changed but still same problem.
I have checked pressure on fuel rail nlpple with dash lights on and off nothing comes out of nipple does this mean fuel pump? Even though it ticks over until temperature reaches 90 and above
Sent from my SM-G960F using Tapatalk
Posted 03 July 2020 - 07:45 PM
Posted 04 July 2020 - 07:40 AM
Does the engine management ligt illuminate? Any fault codes?
The burnt wire seems a good bet - how on earth (no pun) did it get burnt?
Posted 04 July 2020 - 07:49 AM
That plug looks more like one of the O2 sensors, they're 4-pin/wire. I think the crank sensor is 3-pin. Given it's a 2.2, it's possible you may have an unused O2 sensor plug on the loom too, just to add to the confusion.
Posted 04 July 2020 - 08:13 AM
I've been down this route with my old Monaro. Earth issue meaning wires like this were a better bet for return to earth. On that car it was investigate earth issue, find problem(needed to clean up both main earths), renew burnt wires and/or plug, jobs a good un.
Posted 04 July 2020 - 11:21 AM
Posted 04 July 2020 - 12:00 PM
Posted 07 July 2020 - 05:59 PM
Posted 07 July 2020 - 06:49 PM
Does your fuel retun line feel hot, just after it cuts out?
Posted 07 July 2020 - 07:05 PM
About a month ago I took it for a run once about 20/ 25miles it cut out restarted after about 30 seconds went on to cut out 3 times before I got it home
Posted 07 July 2020 - 07:30 PM
Does the grey relay (fuel pump) in the back still look okay?
You can swap it with the one from the horn to be sure,
If that does not help, then the same advice as i gave on facebook: you will have to inspect your fuelpump
Posted 07 July 2020 - 08:31 PM
