Advice Wanted: Forged Turbo Engine
forged turbo engine tuned 500
10 replies to this topic
#1 VXPilot
VXPilot
  • 5 posts
Posted 26 July 2020 - 08:51 AM
Hi All
I am fairly new to the VX community, having owned a 2004 Turbo (stage 2 238bhp) for a year or so, and I must say I am loving it.
I want to swap the current engine and turbo for a forged engine, with a larger turbo and supporting ecosystem such as cooling and fuel. I am thinking maybe a Saab platform. I am looking for 350+ HP and big torque.
Please can you offer some advice on the best route to take to purchasing or building an engine?
Thanks in advance folks!
#2 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 26 July 2020 - 10:12 AM
Have a read of Nev's blog: https://sites.google...te/z20letpower/
#3 Peter VXR29
Peter VXR29
  • 811 posts
  • Interests:Bike and car track days
Posted 26 July 2020 - 12:01 PM
You can forge your current engine with new internals different turbo etc....easily get 400+ hp, courtenay sport did mine, biggest problem I had was pro alloy charge cooler was very prone to fracturing so if doing it again I would def be looking for an alternative or some serious reassurance that this is no longer an issue.
#4 VXPilot
VXPilot
  • 5 posts
Posted 27 July 2020 - 11:18 AM
Thanks Folks :happy:
#5 denno
denno
  • 1,528 posts
Posted 29 July 2020 - 08:35 AM
Would imagine stage 2 to 400hp plus drive in/ out at Courtenay would be very big money.
#6 siztenboots
Posted 29 July 2020 - 10:01 AM
LEH pistons and H beam rods
#7 Nev
Posted 20 August 2020 - 03:56 PM
They can make one with stronger side walls and corner bracing if you ask. I asked for this, as well as a large inlet + outlet pipes and it has surivived quite a lot of 25 PSI and even some runs with 30 PSI in my car over 10 years.
#8 Mattias
Mattias
  • 300 posts
Posted 21 August 2020 - 08:40 AM
I will be putting some remaining parts from my 450+hp previous engine setup for sale. Eg. PWR charge cooler, pump and pro alloy pre-rad. Also have a complete 3" exhaust that fits garrett or BW turbo fitted on Klasen cast manifold.
As already stated above, LEH pistons and better rods and get the block pinned that is what finally gave up from fatigue on mine, can really recommend fitting klasen intake and exhaust manifold in combination with klasen cams.
#9 denno
denno
  • 1,528 posts
Posted 26 August 2020 - 02:52 PM
The drive in/ out cost to go from 300 hp to 400+ hp at Courtenay is eye watering !
Edited by denno, 26 August 2020 - 02:52 PM.
#10 steveboyslim
steveboyslim
  • 120 posts
Posted 14 September 2020 - 10:09 AM
Wedged block,, needs to be bored after, as I did for Simin and Nev.
Thanks
Steve
#11 ditonics
ditonics
    Turbos aren’t as good as NA’s
  • 939 posts
Posted 08 October 2020 - 11:24 PM
That picture is my block back in the workshop after Steve wedged it and bored it - that was some 3 years ago now.
Running 440ish with margin for plenty more.
