Team Dynamic Pro Race 1.2 (?) Don't Fit?
8 replies to this topic
#1 Tupperware
Tupperware
  • 12 posts
Posted 28 July 2020 - 05:15 PM
Hi all,
Recently picked up my VX220. A previous owner put on Team Dynamic wheels which is good and all, but the centre bore seems to be too small? I really had to take a hammer to get them off! I have seen lots of VX's run them, how do people get around that?
The difference in them fitting and being too tight must be ~1mm, could I just sand the inside down a little and repaint?
Cheers all,
#2 redvts
redvts
  • 1,472 posts
Posted 28 July 2020 - 06:51 PM
It's probably just rust on the hub/spigot rather than the wheel, just need a clean up...
#3 redvts
redvts
  • 1,472 posts
Posted 28 July 2020 - 06:52 PM
#4 PaulCP
PaulCP
  • 6,066 posts
Posted 28 July 2020 - 07:19 PM
^^^^ + a bit of copper ease around the spigot and hub plate
#5 Tupperware
Tupperware
  • 12 posts
Posted 29 July 2020 - 07:09 AM
Cheers guys, I thought this at first but I couldn't seem any signs of corrosion, and the previous owner applied a copious amounts of grease. Silly me I never checked to see if there was a spigot ring.
#6 paul_mck
paul_mck
  • 284 posts
Posted 29 July 2020 - 08:00 AM
if they werent right they wouldnt fit. likely painted at a time and the paint got in that area making it seem a bit small. Id sand back a little to make them fit easier but you want them as tight as possible
#7 FLD
Posted 29 July 2020 - 10:17 AM
1mm is a big difference.  This is way beyond press fit and they wouldn't go on at all.  First thing I'd do is give them a damn good clean and see how they fit.  If they're still difficult measure them up.  They should be a close sliding fit.
#8 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 01 August 2020 - 08:21 AM
I ordered a set of TD a red years ago. And I could t fit the fronts because of small center bore. I took them to a wheel specialist which lathed/machined the center bore to right diameter.
And they fit perfect. A misstake by TD, everyone misstakes from time to time.
(I got compensated by the seller)
Br, Per
Hi all,
Cheers all,
#9 oakmere
oakmere
  • 2,143 posts
Posted 03 August 2020 - 11:35 AM
I think some aftermarket wheel hubs were a larger diameter so this may be the source of the issue rather than the wheels.
