Is it possible to replace the hydraulic lifters without taking the timing chain cover off and all the extra work involved with that - new bolt for crank pulley, remove engine mount, really awkward location etc. If I just remove the chain tensioner would that be enough to remove the cams?
Noisy Tappet
Posted 17 September 2020 - 06:15 AM
Posted 17 September 2020 - 07:20 AM
You could try bungee the pulleys up to a bar of some description to keep the tension on. Your biggest problem is if the timing jumps and you don't realise.
I'm presuming you are standard or stage 2 SC with standard cams ?
Posted 17 September 2020 - 10:18 AM
Posted 17 September 2020 - 11:39 AM
So, yes it's possible
Posted 17 September 2020 - 11:53 AM
Posted 17 September 2020 - 02:10 PM
And the work from 47:24min chapter6
Posted 17 September 2020 - 02:38 PM
Posted 17 September 2020 - 03:03 PM
I've heard that the sprockets will still move on the pin when you disconnect them from the cams.
I changed the valve seals by doing so, but only loosened the chain tensioner, and took one camshaft at a time and had no problems.
Posted 17 September 2020 - 07:45 PM
If I'm wrong and they are z22se I'd definitely cable tie the chain to the pulleys as the procedure in the video bares very little resemblance to actually working on a real engine in a real car. 😄 (I love the way things just glide apart with no shite in the way and with no need to do a Mr Fantastic impression ðŸ˜) The chain is unlikely to jump on the bottom crank sprocket as long as you don't drop it but I think something set up with bungee chords would be more reassuring than leaving them hanging on the timing tool.
Only use genuine GM lifters - I tried to cheapskate it in the past and they just couldn't cope with high performance cams and went noisy within a few hours of running.
Posted 17 September 2020 - 07:58 PM
Posted 18 September 2020 - 07:02 AM
Posted 18 September 2020 - 08:12 AM
Posted 18 September 2020 - 06:47 PM
Posted 18 September 2020 - 08:07 PM
Posted 18 September 2020 - 09:30 PM
I can't remember the brand, something like BGA or IVA, but I doubt they manufactured them. Pattern parts like this probably all come out of the same factory and get branded up by various companies.
Unless someone else can chime in with a brand they know works OK with stronger springs just bend over and get GM.
You can't run a VX on a fiver ðŸ˜
