Oil Pressure And Temperature Gauges For Turbo
oil pressure and temperature
8 replies to this topic
#1 rolfb
rolfb
  • 27 posts
  • Interests:Sailing and things with engines :-)
Posted 07 October 2020 - 02:19 PM
....sorry but no android phone. i am a apple boy.
Apple bluetooth / wifi devieces are that expensive because only the certified ones works  thumbsdown
Hi friends,
I am planning some upgrades to my newly aquired "vanilla" Turbo for trackday driving. As part of this, the plan is to increase the BHP.
I know the Turbo is running at fairly high oil temperatures, and I would like to install oil pressure and temperature gauges.
Have any one done that, and what is the easiest way to go? (As far as I can see, the oil readings can not be collected from the OBD2)
- I found some threads, but got somewhat lost :-)
Thanks
Rolf.
#2 ditonics
ditonics
    Turbos aren’t as good as NA’s
  • 939 posts
Posted 08 October 2020 - 11:18 PM
You can't get the oil temp or pressure from an OBD, neither are read. The oil pressure is a switch only.
You will need to fit an oil temp sender and also a pressure sender or a small oil pipe to the back of whatever gauge you fit.
Reasonable simple jobs if you are ok with a spanner.
#3 rolfb
rolfb
  • 27 posts
Posted 13 October 2020 - 07:32 AM
Thanks for your answer
I will grab the spanner and mount some sensors :-)
#4 Nev
Posted 13 October 2020 - 12:43 PM
Hi friends,
Thanks
Rolf.
Why do you think your oil temps and pressures are too high? Thousands of these engines work fine with no problem with oil pressure/temps. I thought of adding such instruments on mine many years ago, but in the end I did not, and I have never needed them really. You can never really have too much oil pressure any way, the more the better really and temps will be regulated well by the oil/water heat exchanger. It works adequately on my tuned car, so think it will be fine on yours.
#5 joshua
joshua
  • 181 posts
Posted 14 October 2020 - 08:23 AM
Oil temp and pressure senders are quite easy to install. My car has them fitted (VXT) by tapping into the ends of the lower oil cooler unions.
Fortunate I had the temp gauge fitted, a few years back on the vigorous climb out of Andorra the oil temp jumped alarmingly after which I fitted a supplemental oil cooler and extra charge cooler radiators. With more power and an even heavier right foot I’ve had no problems since.
#6 rolfb
rolfb
  • 27 posts
Posted 16 October 2020 - 11:50 AM
Thanks a lot for good inputs, gents!
I am planning to take my VXT to around 300 BHP including a larger intercooler and uprated oil cooler. As for instruments: I agreed, that with proper solutions to "heat management", overheating shouldn't be a daily issue, but would like to catch the abnormal issue, before it breaks my engine.
#7 Nev
Posted 16 October 2020 - 08:38 PM
Whats temps did the oil reach Josh? And what was the ambient temps roughly?
#8 joshua
joshua
  • 181 posts
Posted 17 October 2020 - 10:06 PM
115°C peak. Approx 25°C in Andorra La Vella town, 18°C at altitude so not that warm, it was late September. Not seen over 105°C since.
Previous year I roasted the front RC5 pads and slightly warped the standard discs going the opposite way.
#9 scw02102
scw02102
  • 1,581 posts
Posted 25 October 2020 - 02:31 PM
I wouldn’t worry about 115c peak
Just use a decent oil Miller Nanodrive that works up to 150C before any issues
