Battery And Electrical Power.
6 replies to this topic
#1 menright
menright
  • 21 posts
  • Interests:Building Props for TV and Film.
Posted 04 November 2020 - 11:22 AM
Just wondering what size of battery the VX220 Turbo uses in terms of CCA and Amps from the factory. What CCA does the car need realistically to turn over: just wondered how small the battery can go in terms of cranking power?
#2 aquilaproejct
aquilaproejct
  • 267 posts
Posted 04 November 2020 - 10:12 PM
Following.. interested in a small conventional battery as well...
#3 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 04 November 2020 - 10:33 PM
TIS says it's 38 Ah . Don't know what CCA though.
#4 menright
menright
  • 21 posts
Posted 06 November 2020 - 04:22 PM
Thought I might share. If you want a battery that is easy to fit then try one of these. Yuasa YBX5202 battery. High CCA 440 and 45Amps. Best bit though it lowers straight in without having to perform some sort of contortionist magic trick, smaller dimensions from the standard so loads of room to manoeuvre into place. It does sit about 5mm higher than the standard battery so you might have to slightly enlarge the holding brackets holes.
Also might be worth checking out you boot entry battery if you have not used it some time. Mine had exploded and was sitting in a pool of white battery acid powder, good job this car is fibreglass.
Does anyone know if the alternator charges the entry batter through some for of slit charge relay?
Mark
#5 chris
chris
  • 524 posts
Posted 07 November 2020 - 09:16 AM
420 A (30s) -2,4 kg
#6 blackoctagon
blackoctagon
  • 213 posts
Posted 07 November 2020 - 01:43 PM
Its....it's beautiful.
So small, so light......
What type is it? NiMh? Lithium?
I can't read the label, so i'd be grateful for a name or any other details.
Edited by blackoctagon, 07 November 2020 - 01:49 PM.
#7 chris
chris
  • 524 posts
Posted 07 November 2020 - 07:04 PM
https://www.super-b....andrena-12v15ah
But may be you could find similar cheaper battery  ...
Edited by chris, 07 November 2020 - 07:05 PM.
