Few spares which maybe of use or good backup items. I can send pictures if needed. All items plus p&p cost
VXT water ingress cover, just the black metal folded metal part, no fitting screws inc - £35
Mk5 5 astra/zafira vxr battery wiring loom, has had some wired unwrapped p/n 55561069 - £10
VXT engine mount bracket - the steel black on, could do with a clean and lick of paint - £10
VXT zlet multilayer headgasket - £5
VXT zlet headbolt set - £5
VXT airbox mountin bracket and plastic/rubber bung mounting part- £5
VXT metal mounting bracket for coolant header tank - £5
VXT engine wiring loom blue/black connectors to injectors etc onward loom cut - £10
VXT throttle body x2 p/n 0280750048 - £50 each
VXT coolant hose and coolant run on pump p/n 90424271 - £10
VXT coolant hose with T and turbo return hose/banjo p/n A116K0030 - £15
VXT coolant hose and bleed valve p/n A116K0032 - £15
Turbo braided oil hose to block p/n 90424174 - £5
VXT crankcase breather 90deg hose oem brand new p/n 90423667 - £10
VXT starter motor p/n 001107101 - £40
VXT alloy gear knob, few marks - £10
VX220 new rear roll over plastic part which roof bar sits in p/n 9197713 £1 posted
Zlet set of 2nd hand rods - £10
Would do a deal on everything for £250
Garage Clearout Vx Spares - Water Ingress Cover, Water Hoses, Wiring E
Started by
Duncan VXR
, Jan 10 2021 04:40 PM
4 replies to this topic
Posted 10 January 2021 - 04:40 PM
Posted 10 January 2021 - 07:38 PM
Provisionally sold
Posted 10 January 2021 - 09:24 PM
Provisionally sold
Posted 11 January 2021 - 06:38 PM
Provisionally sold
VXT engine mount bracket - the steel black one, could do with a clean and lick of paint - £10
Posted 12 January 2021 - 03:18 PM
SOLD
VXT alloy gear knob
VXT alloy gear knob
