Piper Vx22Bp270 Camshafts , Or Others Considered
Posted 19 January 2021 - 05:45 PM
The other brands are also of interest, such as the Catcams 259,267 and 277 and the Compcams 256,262 and 268.
If you have some for sale i'd be grateful to know, and also what you would want for them, posted.
I have a set of OEM that I can send for rework, so I can go new if need be, alternatively can build them into a part exchange deal.
Posted 20 January 2021 - 07:39 PM
I am looking for the pair of Piper cams with the 10.7mm valve lift and the 266 duration.
Do you need a long exhaust cam for the Z22SE head, or a short one for fitting a B207 head?
I have a pair of Comp cams. Need to check the grind numbers .
Posted 21 January 2021 - 09:35 AM
Posted 21 January 2021 - 11:20 AM
Posted 21 January 2021 - 06:08 PM
How do you view that failure;
Was it bad workmanship/finishing or do you suspect an actual problem with the cam profile?
Was it one rocker or was there signs oon the others as well?
Edited by blackoctagon, 21 January 2021 - 06:08 PM.
Posted 21 January 2021 - 07:57 PM
Perhaps the reduction in base circle was the cause of failure.
Posted 21 January 2021 - 08:06 PM
I sent them all the damaged components and samples of the lifters in adjacent cylinders which clearly show signs of trying to operate beyond their intended range.
Sadly they deny fault and blame the failure of the single rocker.
Posted 22 January 2021 - 08:10 AM
I was always under the impression you should fit lash adjuster shims/spacers on the Z22 when fitting regrinds. I am surprised Piper don't recommend it, or at least mention it in the instructions, instead of suggesting it after you have had a failure!
Posted 22 January 2021 - 11:38 AM
Posted 22 January 2021 - 07:29 PM
I'm not against making and hardening some shims, but i'll call that Plan B for now.
Posted 26 January 2021 - 08:14 PM
Is it a simple job to retro fit the shims or is it a PITA ?
Posted 26 January 2021 - 09:01 PM
Posted 26 January 2021 - 09:14 PM
Because these are between the head and the lash adjuster you may get away with a lesser steel or the heat treating.
If you have the cam train already out then fitting then fitting is simple - drop them down the lash adjuster bore then pop in the lash adjuster.
[edit] Or go mental - https://www.jesel.co...d-cam-followers
Edited by blackoctagon, 26 January 2021 - 09:19 PM.
Posted 27 January 2021 - 02:48 PM
that sounds like fun.......
Can shims be purchased of the correct size etc ???
Asking for a friend
Posted 27 January 2021 - 06:45 PM
