Hi,
What are the current options for front and rear engine mounts?
I've seen the Powerflex and Vibra-Technics, but which is the best?
It is road use and I don't want to increase the vibration.
Thanks
John
Posted 27 February 2021 - 12:43 PM
Hi,
Thanks
John
Posted 27 February 2021 - 02:47 PM
Posted 27 February 2021 - 03:21 PM
Mine also has balance shafts removed.
The reason for looking at these is that it is quite noise. I was convinced it was the side mounts, but had those changed. The noise continued so thought it must be the front or back.
I've found that the rear already has poly inserts, but it is fairly squeaky, so it could be that making the noise. They don't look in bad condition to me, how would I know if they need replacing.
Posted 27 February 2021 - 03:26 PM
Posted 27 February 2021 - 03:32 PM
Posted 27 February 2021 - 05:15 PM
Posted 28 February 2021 - 08:58 AM
Posted 28 February 2021 - 10:16 AM
Cheers for the comments.
Think I'll order another power flex bush for the front and then lube it all up and put it back. Hopefully that will end the noise.
Posted 28 February 2021 - 06:13 PM
i can supply you the powerflex mounts if you like
Posted 28 February 2021 - 07:07 PM
PM sent
Posted 12 March 2021 - 11:41 PM
