Fuel Pump Dead?
11 replies to this topic
#1 Lordm695
Lordm695
  • 21 posts
Posted 26 March 2021 - 02:53 PM
Hi, firstly massive thanks to Type116, sent me an alternator, belt and tensioner when mine died a couple of weeks ago. All fitted easily enough and everything seemed ok but didn’t drive the car until a couple of days ago and it cut out on me about 10 min down the road. Restarted a minute later and cut out twice on the way back home.
Fault codes...
P0378
C3F00
P0201
P0202
P0203
P0204
P1515
P1516
P1512
Checked all the earths, loom connectors, throttle connector, batery etc...cleared codes car restarts but dies after a few minutes with the same fault codes.
But now fuel pump not priming, checked relays in boot and blown 20A fuse. Replaced fuse but no power to relay or loom connector (fat pink’n’brown wire)
What next, cut hole and check fuel pump.
Thanks in advance for any advice.
Oh also cleaned coil pack and plugs.
#2 smiley
Posted 26 March 2021 - 03:43 PM
From my little ecu codes collection i build up over the years.
It's fixes reported on the site here. Not a guarantee.
#3 Lordm695
Lordm695
  • 21 posts
Posted 26 March 2021 - 03:58 PM
Thanks smiley forgot to say its a NA
Swapped grey relay with one from the front
All relays look surprisingly clean from what I’ve read on here
Checked  and cleaned blue and black connector many times
Checked battery earth but made an extra one temporarily with a jump lead, battery is in good health.
But no power to fuel pump relay......
#4 Lordm695
Lordm695
  • 21 posts
Posted 28 March 2021 - 12:56 PM
So this morning checked the to 50A fuses near the wipers and one was half out but still ok.
Was about to cut out the fuel pump to check but decided to search a bit more and read something by “Zoobeef”
Apparently the brown relay feeds the grey so took the relay out to check and it seems to be faulty.
Ive ordered  a replacement so fingers crossed  that’s the problem
#5 Horace
Horace
  • 1,290 posts
Posted 29 March 2021 - 08:33 AM
Also check the 4 big fuses on the left side of the boot (under a cover).
#6 Lordm695
Lordm695
  • 21 posts
Posted 30 March 2021 - 09:03 AM
Thanks Horace I only found 2 fuses which I think is an NA thing.
Brown relay just arrived so fingers crossed
#7 Lordm695
Lordm695
  • 21 posts
Posted 06 April 2021 - 01:15 PM
All sorted, drove for an hour today and all good.
So if your fuel pumps not priming check the brown relay.......
#8 iceman
iceman
  • 18,159 posts
Posted 06 April 2021 - 01:53 PM
Good Afternoon.
Soooo happy to see a plan come together. If ever there was! an A Team, i'd make you go first to wheedle out the good luck and leave the rest drugged-up on a plane, lol
Hope your travels carry on now problem free.
..icey
#9 kpf1grandprix
kpf1grandprix
  • 151 posts
Posted 06 April 2021 - 06:30 PM
Hi mate where did u get the relay cheers
#10 Lordm695
Lordm695
  • 21 posts
Posted 07 April 2021 - 04:52 PM
Rimmer Bros
AMR1088
RELAY BROWN GENUINE
£12
#11 kpf1grandprix
kpf1grandprix
  • 151 posts
Posted 07 April 2021 - 07:28 PM
Rimmer Bros
AMR1088
RELAY BROWN GENUINE
£12
Just paid £13 for a second hand One doh!
#12 iceman
iceman
  • 18,159 posts
Posted 07 April 2021 - 10:51 PM
Rimmer Bros
AMR1088
RELAY BROWN GENUINE
£12
:lol:  oops!
Please disregard my previous post (not that you weren't  :P )...it becomes apparent that with your actual level of luck, you will be first! on the plane  :poke:
