Fuel Pressure Regulator, 2.2 N / A
31 replies to this topic
#1 clipping_point
clipping_point
  • 4,908 posts
Posted 12 December 2004 - 12:59 PM
Found this on J-body:
"2003 ecotec owners can now have a afpr that will directly bolt up to the fuel rail. it is a
1995-1995 Lt-1 fuel pressure regulater that i picked up from holley but jegs has a aeromotive part # 027-13107 . it has to have the bolt on the font and have the fuel line fitting on the right . you will also need a fuel pressure gauge that can be tape on to the shrader valve. if you have a 2002 cavalier you will need a fuel rail and lines and injecters from a 2003 cavalier. check out my profile bbsecotec for more info and pics
this only works for a n/a motor"
Here it is:
AFPR
Couldn´t it be used to richen the flow, in order to fit a 270-275° cam, to pump out 210 HP, with the standard ECU??
#2 clipping_point
clipping_point
  • 4,908 posts
Posted 12 December 2004 - 10:08 PM
Price is $150 + shipping, but a guy at J-body may arrange a better deal, this tuesday thumbsup
#3 clipping_point
clipping_point
  • 4,908 posts
Posted 13 December 2004 - 07:55 AM
This ones fitting as well, but maybe worse quality:
http://www.hopupraci...adfuprreco.html
#4 vocky
Posted 13 December 2004 - 11:08 AM
Certainly a mod which will be needed @190+ bhp,
There are other upgrades possible, the saturn ion redline 2.0 sc item can be found at autopartspeople.com.
And closer to home there maybe a vx upgrade possible, I will post more info at a later date.
Edited by vocky, 13 December 2004 - 11:10 AM.
#5 clipping_point
clipping_point
  • 4,908 posts
Posted 13 December 2004 - 11:35 AM
At 36 bucks!! :o
#6 #2177
#2177
  • 92 posts
Posted 16 December 2004 - 07:32 AM
Guys. the complete upgrade is available at HITEC, including installation and all the material, that you would need in aaddition to the GM parts.
http://www.vx220.org...=ST&f=9&t=16749
#2177
#7 clipping_point
clipping_point
  • 4,908 posts
Posted 16 December 2004 - 08:46 AM
Thanx! I guess I could ask them, then. We´re engineers tho, not millionairs...... :)
#8 cicastol
cicastol
  • 423 posts
Posted 16 December 2004 - 01:32 PM
next week i will have more info on Bosch motorsport fuel pressure regulator,i want to increase the fuel pressure by 0.5bar for extra fuelling in WOT to cope with my free exhaust (bigger bore,no kat) :D
#9 vocky
Posted 16 December 2004 - 02:16 PM
Standard fpr relief pressure is 3mB, vauxhall part number 9198822 fpr is 3.8mB, I have one - but have not fitted it yet. It's the same external size, but will not know if its OK until I hopefully fit it this weekend :)
#10 cicastol
cicastol
  • 423 posts
Posted 16 December 2004 - 02:36 PM
Standard pressure is not 3mB(millibar) but 3000mB or 3Bar,beware going over 3.5bar because this can stress the fuel pump too much!
Edited by cicastol, 16 December 2004 - 02:37 PM.
#11 vocky
Posted 16 December 2004 - 02:58 PM
Yes you are quite correct 3 Bar standard and 3.8 Bar for the other one :beat: . Fuel pump should be ok, but for less than £18 a very cheap upgrade :)
#12 vocky
Posted 18 December 2004 - 10:50 AM
Right then, the vauxhall item (9198822) will NOT work :( the Aeromotive one (if that is the correct pic) will NOT work :( so we await the Bosch details please 'cicastrol' thumbsup
#13 cicastol
cicastol
  • 423 posts
Posted 18 December 2004 - 12:14 PM
I will let you now during next week.
#14 clipping_point
clipping_point
  • 4,908 posts
Posted 18 December 2004 - 01:47 PM
Cost? U need a gauge to see what pressure u have also, I guess?
#15 #2177
#2177
  • 92 posts
Posted 18 December 2004 - 02:10 PM
We have messured fuel pressure. It is 4 bar in a standard N/A! We have modified it to jump to 4.5 bar when he supercharger needs the fuel. Where do you find the 3.0/3.8 bar? #2177
#16 cicastol
cicastol
  • 423 posts
Posted 18 December 2004 - 02:56 PM
#2177
Not mesured yet,i'll mesure the fuel pressure next Wednesday,but if you mesured it at 4 bar i belive you!!
I said 3 bars only because normally this is the standard fuel pressure found on many cars.....
How you modified the standard fuel pressure??? By compress it a little bit??
Thanks for info!
#17 clipping_point
clipping_point
  • 4,908 posts
Posted 18 December 2004 - 03:56 PM
Make sure you speak about the right kind of pressure ..........if cicastol is talking bar(e) and #2177 is talking about bar(a) ....then you are saying the same thing, both of u! ;)
#18 #2177
#2177
  • 92 posts
Posted 18 December 2004 - 09:06 PM
We are using the the additional 0.5 bar from the supercharger and put them from the intake to the membrane of the pump. This helps together with larger injectors to keep lamda=1 while getting to the high power. #2177
#19 vocky
Posted 19 December 2004 - 09:01 AM
The standard fpr looks like figure D in the Bosch download, so B 280 550 341 looks like the one required. (or is it :wacko: )
#20 SpunkyM
SpunkyM
  • 4 posts
Posted 20 December 2004 - 04:33 PM
It might be worth just pointing out that upping the fuel pressure is only desirable if your ECU is mapped for it. Basically this means using a mappable chip setup on the rolling road. The problem with using an increased fuel pressure on a std ECU is that the map will specify a certain injector duration for a given airflow. The feedback loop via the lambda sensor is usually ignored on heavy throttle so the ECU has no way of knowing if the fuelling is rich, which of course is not a good thing.
