It's at the bottom of this PAGE, just above the shiny new replacement caps for the water and engine oil in the engine bay....want some of those
Does it never stop
Posted 21 December 2004 - 07:52 AM
Posted 21 December 2004 - 08:07 AM
Posted 21 December 2004 - 08:33 AM
Well I can vouch it is RED...I was told that the red GM fluid is synthetic already, so I stick with it for now...
Edited by trescoman, 21 December 2004 - 08:33 AM.
Posted 23 December 2004 - 03:38 PM
Posted 23 December 2004 - 07:02 PM
If you could Bob as I will pick some of this up next time I am at courteany'sanybody wants a "how to do it" chapter in the DIY section, I'll do one.....there a few things that I would do different if I had to do it again
Posted 23 December 2004 - 09:04 PM
Posted 24 December 2004 - 02:20 PM
Xmas job for me then...no prob'sIf you could Bob as I will pick some of this up next time I am at courteany'sanybody wants a "how to do it" chapter in the DIY section, I'll do one.....there a few things that I would do different if I had to do it again
P.S that will be when I get the miltek![]()
Posted 20 May 2005 - 09:51 AM
Edited by Ricky2772, 20 May 2005 - 09:55 AM.
Posted 23 May 2005 - 12:19 PM
Posted 23 May 2005 - 04:55 PM
Posted 23 May 2005 - 09:16 PM
Posted 24 May 2005 - 05:54 PM
it will be D4 ATF....our gearbox need dextron III -compatible fluid.Which one do you plan to use ??
MTL...MT90 or else ?
Phil
Posted 24 May 2005 - 06:40 PM
No, No... i've the manual gear box option on mineit will be D4 ATF....our gearbox need dextron III -compatible fluid.Which one do you plan to use ??
Phil
http://www.redlineoi...=59&subcatID=19
Posted 24 May 2005 - 08:51 PM
Posted 24 May 2005 - 09:28 PM
Yes it is .At the risk of sounding stupid here, where is the thing to check fluid levels in the gearbox. Just a little concerned as took it round the track last week and found transmission fluid had leaked. Is this normal when taken on the track?
Posted 25 May 2005 - 10:28 AM
yes, it means that you have too much oil in the box AND you do not double-shift/match engine revs when downshifting.Is this normal when taken on the track?
Posted 27 September 2005 - 08:40 AM
Edited by Ricky2772, 27 September 2005 - 08:43 AM.
Posted 27 September 2005 - 10:40 AM
Or you just need a gearbox breather fitting. Vauxhall did mine for me under warranty.yes, it means that you have too much oil in the box AND you do not double-shift/match engine revs when downshifting.
Posted 27 September 2005 - 03:17 PM
Edited by Speedster Man, 27 September 2005 - 03:18 PM.
