Redline Gearbox Oil
36 replies to this topic
#21 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 02 November 2017 - 11:56 AM
Hello,
More people running Redline oils??
Maybe taking the plunge also.....
I'm using Fuchs 75W80 (GL5, bit weird because the F23 is a GL4 tranny) in a high powered turbo. My tranny oil dies after 2000km 's. It REALLY does!
The Fuchs gearchanges are great and i do not want to lose it.
So.....
Which one to choose????
MTL 75W80 ( has the GM synchromesh spec in it)
MT 85 (oem gearbox fluid is a 75W85 also)
MT90 (maybe better for extreme wear and tear,higher temp. resited)
Best thing is offcourse the Redline is a GL4 spec.
I do NOT track the car, but when giving it the beans   temperature of the oils rise fast!
All oils are Fuchs in the car.
grtz
ps: 2 litres of Fuchs 75w90 LS (GL4/GL5) spec are also on it's way to test..... Are there members running this gear oil????
pps : NO oem GM oil! removed it after 1500km. Burned smell!
Edited by tibby, 02 November 2017 - 12:02 PM.
#22 Exmantaa
Posted 02 November 2017 - 05:33 PM
So... If the Fuchs is great, but off after 2000km's, you better fit a gearbox cooler of some kind. ;-)
#23 ultimate
ultimate
  • 261 posts
Posted 02 November 2017 - 08:10 PM
I had the Fuchs oil in my gearbox but changed it to Rowe gearbox oil. (Because of other problems - were not caused by the oil) Do you measure your gearbox oiltemp? I never see more than 80-85 degree.
#24 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 02 November 2017 - 09:17 PM
That would be the case if other oils do not work  :yeahthat:
For only  street usage thougth a gearbox cooler would not be needed...... Summer time i drive with a half undertray (Europa style)
I'm looking for a 'cheap fast fix' solution first....
grtz
#25 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 02 November 2017 - 09:31 PM
  Hello,   No , i do'nt measure my gearbox temperature (but would really like to know it!). Notice my engine oil rises with 10 degrees . So box temperature would rise also... I do notice a different gear change when riding hard/getting hotter  with the Fuchs.   Maybe a 90w is a bit better for higher temp /heavy load in my gearbox. Fuchs is 75W80 i'm using now...   That's why i'm going to test the Fuchs 75W90 limited slip (have a lsd fitted) . This one is also a GL4/GL5 classified. The 80w is a GL5 one.   But reading a lot of positive reviews (some negative also) about the Redline oil i would like to try it....   Ultimate, you're using this one? https://www.motor-oe...haltgetriebeoel
Edited by tibby, 02 November 2017 - 09:40 PM.
#26 ultimate
ultimate
  • 261 posts
Posted 03 November 2017 - 09:15 AM
Yes, the can looks a bit different now but the description is the same
#27 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 03 November 2017 - 10:27 AM
  Also has the GM spec on it (•GM 1940182)  :)
#28 2-20
2-20
  • 1,317 posts
Posted 03 November 2017 - 12:39 PM
I have MTL in mine and Will switch back to OEM. I don't like the feel when shifting to fifth Gear ... It seems that it does not synchronize Well and quick enough.i m faster to shift to 5 when double shifting with neutral between change.
#29 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 04 November 2017 - 01:36 AM
Hello, thanks for this information!!! So the MTL one i can scrap of my list.. The MTL is a 80w. Maybe change to the mt85 or mt90?
#30 2-20
2-20
  • 1,317 posts
Posted 04 November 2017 - 03:34 PM
Yes, mt85 should be the correct one.... I used MTL just because I had 2 bottles available (planned to be used elsewhere before).... And thought that it could be OK despite the little viscosity difference.
#31 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 04 November 2017 - 06:23 PM
I'm going to order the MT85. Did put the FUCHS 75W95 LS GL4/5 in  today. Stiffer gearchanges. Could not choose 2nd gear sometimes..
80W VS 90 W = big difference in thickness of fluid. The 80 w is like water compared to the other one....
My 2 options i'm going to take are : CAstrol Syntrans 75W85 GL4 , but first the MT85.
Like the manual says: 75W85 GL4 and NOTHING else! Hopefully it 's the best of 2 worlds. Good cold gearchange and good temperature/load protection....(like it should be)
#32 gertje
gertje
  • 459 posts
Posted 05 November 2017 - 01:18 PM
I think they problem is, you need to learn to shift Tibby Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
#33 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 05 November 2017 - 03:43 PM
I think they problem is, you need to learn to shift Tibby Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk [/quote Nope, to much power
:gayfight:
#34 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 05 November 2017 - 03:46 PM
Ordered this time the   Castrol Syntrans 75w85 GL4 oil. This is also the exact oem spec. https://www.google.b...0W2OfmelIS72Qrj grtz
#35 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 10 January 2018 - 04:54 PM
Well, back to the redline.... Flushed my brand new Castrol (did 2 previous castrol flushes) with the redline mt85. All i can say is: wish i did not do this.  :dry:
#36 2-20
2-20
  • 1,317 posts
Posted 11 January 2018 - 06:50 PM
I've changed my Redline MTL oil with OEM oil In the hope to get a better feel. But no difference...
#37 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 11 January 2018 - 11:25 PM
My experience is the MT85 has a bit stiffer gearchanges when cold compared to the Castrol 75W85. Both are tested in the same °C
They both have the same spec: 75W85 GL4.
I'm switching back to the Castrol .
For now my choices are:
standard speedster/vx = Fuchs 75w80 GL5 (weird but it's a really good transmision oil BUT does not last long in a highly tuned vx/speedster)
Tuned vx/speedster: Castrol Syntrans 75w85 GL4
I've waisted a lot euro's testing different gear oils....
-Castroll 75W90 gl4 Syntrans: to thick but shifts ok
-Fuchs : 75w80 gl5 : very good for a standard car smoothest gearchanges i had!
-oem GM oil: smelled burned after 1500 km
-Fuchs  75w90 LS GL4/5 : no gearchanges possible!!!!!!!
-Castrol 75W85 gl4 Syntrans: Does the job for me
-Redline mt85 : to thick but shifts ok , very expensive oil!!
I'm done testing (remember i Always flush my tranny and refill )  :D
