Posted 25 January 2005 - 03:47 PM
Posted 25 January 2005 - 03:59 PM
Posted 25 January 2005 - 04:17 PM
...a bit suspicious this time...took her time to approach it....
Where's the cat??
Posted 25 January 2005 - 04:20 PM
Posted 25 January 2005 - 04:28 PM
495£ + vat (if not exempt) and shipping...how does a LSD help ? take it's expensive.. and only really for heavy modded cars?
Posted 25 January 2005 - 04:36 PM
Posted 25 January 2005 - 04:37 PM
Posted 25 January 2005 - 04:39 PM
Posted 25 January 2005 - 04:40 PM
Posted 25 January 2005 - 04:41 PM
Posted 25 January 2005 - 04:54 PM
Posted 25 January 2005 - 05:02 PM
...you getting a cat?Will soon be joining you Ricky.......
Posted 25 January 2005 - 05:03 PM
Posted 25 January 2005 - 05:08 PM
Ricky, do you have enough negative travel on your rear wheels? Should be about 50 - 60 mm measured on the wheel.I currently spin inside wheel on all slow/medium corners, even in 3rd gear +yoko 048... not to mention at the ring....quite frustrating at times....
Posted 25 January 2005 - 05:09 PM
Posted 25 January 2005 - 05:16 PM
erm...what is that?Ricky, do you have enough negative travel on your rear wheels?
Posted 25 January 2005 - 05:27 PM
Posted 25 January 2005 - 05:28 PM
Yes!erm...what is that?
Ricky, do you have enough negative travel on your rear wheels?![]()
.....mmmaybe how much the susp. extends when lifting the car?
Posted 25 January 2005 - 05:37 PM
lol, got 2 already.....they aren't as famous as yours....you getting a cat?Will soon be joining you Ricky.......
Posted 25 January 2005 - 06:08 PM
There are both grossly obvious effects and quite subtle unexpected effects. However, in summary, it makes the car more predictable to drive and a good deal less likely to bite you when you least expect it.Ian, how does it feel to drive? Is it more tricky when it breaks away, or more consistent?
I would guess you notice it hanging on for longer before the wheels start to spin under power?
