4 Point Jacking
29 replies to this topic
#21 garyk220
garyk220
  • 3,035 posts
Posted 22 February 2005 - 12:04 PM
Pic showing the C jacking point (fuel tank cover next to the rear wishbone mount). This is from the Opel Tech Centre.
#22 garyk220
garyk220
  • 3,035 posts
Posted 22 February 2005 - 12:06 PM
second showing location on 4 pt lift...
Edited by garyk220, 22 February 2005 - 12:07 PM.
#23 ChazUwe
ChazUwe
  • 2,450 posts
  • Interests:Cars, Computers, Drinking and travelling about.
Posted 22 February 2005 - 09:51 PM
Thats great Gary, thanks for the pictures. So I just need to remove the larger undertray to reveal those points and we should be sorted! Thanks for the help all! Will be much easier standing up...... Cheers Charlie
#24 caleebra
caleebra
  • 4,479 posts
Posted 08 July 2005 - 09:24 AM
Raising an old thread here, but it's MOT time and I'm wanting to take it to a local garage that I can trust as opposed to main dealer who will probably tell me the car needs all and sundry. The two garages I have spoken to have four-post ramps, and from what I understand, usual MOT procedure would be using those sliding scissor jack things to raise the whole front end to check steering out. Then drop the front end and raise the back end to check whatever they do there. Question is, well erm, has anyone watched their car being MOT'd with that sort of equipment? I did try a search, the Hoff would've been disappointed with me if I hadn't :D
Edited by caleebra, 08 July 2005 - 09:25 AM.
#25 caleebra
caleebra
  • 4,479 posts
Posted 08 July 2005 - 02:12 PM
:tumble: Can anyone comment if it's undertrays off jobbie for that sort of lifting? :unsure:
#26 paulf-cam
paulf-cam
  • 1,186 posts
Posted 08 July 2005 - 02:35 PM
Well, you can't get to the back jack points with the undertray on - they lie underneath.... :(
#27 Thorney
Thorney
  • 11,404 posts
    Fluffy bunny rabbits.
Posted 08 July 2005 - 06:38 PM
The process you describe should be fine thumbsup As long as they use the centre raising points and balance the car.
#28 caleebra
caleebra
  • 4,479 posts
Posted 11 July 2005 - 08:47 AM
I'm confused now :o
Jack it up at the trolley jack points? And balance it how? :unsure:
#29 Thorney
Thorney
  • 11,404 posts
Posted 11 July 2005 - 09:44 AM
You've got a couple of choices, all depends on whther you have a 4 post or 2 post lift. As you're talking about a 4 post then these have a slide between the wheels use this to the centre jacking points anf the whole raises off the floor. The back will likely drop down so a couple of bits of wood at the back of the chassis rail or under the rear suspension mounts should be used to stop it dropping too far (although the cars weight is actually supported by the centre jacking points.
#30 caleebra
caleebra
  • 4,479 posts
Posted 11 July 2005 - 10:17 AM
Ok, got it now thumbsup Cheers John, the heat's confusing me :beat:
