Stiff Gears
28 replies to this topic
#1 paulvx220
paulvx220
  • 6 posts
Posted 16 March 2005 - 06:18 PM
IN THE MORNINGS MY CAR IS HARD TO GO INTO REVERSE GEAR, IS THAT NORMAL OR IS THERE ANYTHING I CAN DO TO CURE THIS
#2 willow
willow
  • 2,327 posts
  • Interests:skiing, snowboarding and wakeboarding
Posted 16 March 2005 - 07:06 PM
Whats the Age of your VX?
#3 paulvx220
paulvx220
  • 6 posts
Posted 16 March 2005 - 07:07 PM
OCT 2002
#4 willow
willow
  • 2,327 posts
Posted 16 March 2005 - 07:09 PM
Could be play in the gear linkage, warranty job as long as they replace it thumbsup
#5 paulvx220
paulvx220
  • 6 posts
Posted 16 March 2005 - 07:12 PM
OK , I HAVE A LOK AT THIS , IF NO JOY I WILL GO TO VAUXHALL . THANKS FOR YOUR HELP
#6 Pedro
Pedro
  • 404 posts
Posted 16 March 2005 - 07:21 PM
Mines a bit stiff in the morning :blink: , try putting it into first and then try reverse - this always works for me thumbsup Is your CAPS LOCK stiff aswell?? ;) :P
#7 Jim_Cross
Jim_Cross
  • 4,539 posts
Posted 16 March 2005 - 08:16 PM
Mine can be tricky in 1st and reverse when cold. After starting the car and before setting off, just nip through 3rd and 4th a few times thumbsup
#8 Pedro
Pedro
  • 404 posts
Posted 16 March 2005 - 08:19 PM
There you go - waggle your knob around a few times before slotting it home thumbsup ;)
#9 cyberman
cyberman
  • 652 posts
Posted 16 March 2005 - 09:15 PM
This seems to be not uncommon. Mine has always been f***ing impossible to get into reverse when cold and 2nd isn't much good either. I have had it fixed once and I suspect the problem may be a sloppy gear linkage. If you get a result please share it. Kind regards - Ian
#10 benw
benw
  • 7,806 posts
Posted 16 March 2005 - 10:08 PM
Mines the same. Warms up after 5 mins or so.
#11 kipper
kipper
  • 2,364 posts
    Smoking various types
    of fish.
Posted 16 March 2005 - 10:16 PM
Never a truer word was said
:D :D :D
#12 Whiteboy
Whiteboy
  • 6,950 posts
Posted 17 March 2005 - 12:10 AM
It might be worth topping up the gearbox oil as the car might have been tracked and lost some. thumbsup
#13 Neil G
Neil G
  • 216 posts
Posted 17 March 2005 - 07:51 AM
I find pumping the clutch a couple times helps thumbsup
#14 PJG
PJG
  • 1,007 posts
Posted 17 March 2005 - 07:52 AM
thumbsup thumbsup always does the trick.
#15 chuno
chuno
  • 3,953 posts
  • Interests:Cars, Football (playing and watching)
Posted 17 March 2005 - 09:52 AM
Mines usually quite difficult to get in 1st and reverse when cold, but dont really think anything of it as most of my previous cars have done the same, as said before, just put it through the rest of the gears first
#16 MAP18W
MAP18W
  • 348 posts
Posted 17 March 2005 - 10:03 AM
Fully synthetic gearbox oil helps with the gearchange too.
#17 trescoman
trescoman
  • 1,906 posts
  • Interests:Retirement ASAP, <br>Driving<br>Carp fishing<br>Football<br>kids
Posted 17 March 2005 - 11:10 AM
you don't any do you :P
for those that haven't changed theirs I would recommend it thumbsup
#18 Whiteboy
Whiteboy
  • 6,950 posts
Posted 17 March 2005 - 11:24 AM
Iam still running my gear box in. :beat: Although I have taken the plunge and gone for a CS2 and the brakes. :D You are a bad influence on me Bob. :lol: I just hope I can keep up with you and Mark with the CC. :rolleyes:
#19 trescoman
trescoman
  • 1,906 posts
Posted 17 March 2005 - 12:11 PM
atta boy thumbsup , you won't regret it :rolleyes:
no chance :P
#20 MAP18W
MAP18W
  • 348 posts
Posted 17 March 2005 - 12:15 PM
no chance :P
Not once my cams are fitted :D :D
rallly
