pretty much confirms in my mind that all these issues are tyre wear related and not mechanical.
Can anything be done if its a tyre wear problem?
Ta, Paul.
Posted 13 June 2005 - 07:46 AM
Posted 19 September 2005 - 01:25 PM
Posted 19 September 2005 - 01:27 PM
Bringing up some old stuff, but here's an idea..
I've read on a site that locking wheel nuts can sometimes weigh more or less than the others. Although this translates to much less of a difference in weight on the wheel rim, it can make a difference enough to cause vibration.. Fitting counterweights naturally solves the problem...
Edited by paulf-cam, 19 September 2005 - 01:29 PM.
Posted 19 September 2005 - 04:00 PM
I dont think you'll get away from that with the amount of negative camber compared to your GolfProblem was traced to uneven front tyre wear (wearing from the inside out) They are 4 mm on the outside going to 2 on the inside. Belmont kindly played around with the balancing weights (and their position on the rims) and the vibration is much better....
