Wide Wheels
#21
Posted 19 September 2005 - 05:31 PM
#22
Posted 19 September 2005 - 06:02 PM
#23
Posted 19 September 2005 - 06:26 PM
#24
Posted 19 September 2005 - 06:29 PM
Obviously any different wheel tyre set up will function differently. The manufacturer have set the car up (supposedly) to work well with the standard equipment. After any change you'll really need a geo set up to get it working at its optimum.You can't just say because the Exige has it that it will work, the car has completely different suspension.
Eliminating understeer is one thing but eliminating precious feedback is another. I would rather have a better driving experience than more grip.
If understeer is a problem for people, why not get a anti roll bar upgrade? Or buy a book where you can learn about weight transfer and stop the problem yourself.
-Rob
I was really talking from the view of a track day enthusiaist. Personally if I changed wheel/tyre set up I'd want to do the suspension aswell.
For basic road use i think the standard set up is fine...you have to be pushing hard to notice real understeer problems,
#25
Posted 19 September 2005 - 06:41 PM
Feck, that sounds a bit unreasonable. I got mine fitted for £105 recently. That was at Farmer Autocare.Not at all, infact my car hardly had any understeer..What is the point in this? Are you guys really finding that your cars are understeering that much?
Im just a cheapskate who refuses to pay £135 each for 175/45/17 fronts![]()
#26
Posted 19 September 2005 - 07:32 PM
#27
Posted 19 September 2005 - 08:19 PM
#28
Posted 19 September 2005 - 11:01 PM
Mine dont so you all got a 50/50 chance of it happeningFWIW - 205/40-17's will just rub on the chassis, but only 100% lock.
Foxys tyres must of been abit flat
#29
Posted 20 September 2005 - 06:50 AM
#30
Posted 20 September 2005 - 12:47 PM
#31
Posted 20 September 2005 - 01:39 PM
Try and find a tyre with a suitable load rating. From memory, the standard fronts are 81V/W. Most of the 17" tyres will be 87-91 load rating, if not higher. I'm running Yokohama A539 tyres at the moment (205/50 on 16" wheels).Also, what tyres can you get for this rim? I had Yokohama on a Cavalier 2.0SRI once and they were fantastic although they did wear quite quickly. Brilliant road holding though.
The side walls are very stiff, meaning that the tyre doesn't flex enough, and this reduces the effective footprint of the tyre on the road. When the car is stationary, only the central part of the tread is in contact with the road. The extra load when cornering flattens the tyre out, but you can get caught out occassionally when braking on certain road surfaces. The Bridgestone tyre has a much flatter profile...
more like this |_| than the U shaped Yoykahama, so is much better suited to the lighter VX chassis.
Oh, and my nearside tyre rubs slightly, but only on full lock. The offside tyre is at least 5mm clear of the chassis
