Amd Rolling Road Day Results
#41
Posted 05 August 2003 - 10:23 AM
#42
Posted 05 August 2003 - 10:37 AM
#43
Posted 05 August 2003 - 10:39 AM
#44
Posted 05 August 2003 - 10:43 AM
as my car was running lean and the engine management was cutting off power by between 10-15%
minime
I would personally absolutely no way run software that acts like this! You are relying on the ECU and its sensor inputs to try and correct a fault that is apparently being created by the software, it only needs one time for this not to get corrected, or not to be able to retard the ignition enough, and you may end up with a nice big ventilation hole in a piston! The hot weather will only exacerbate this!
I an not knocking the software, but your engine may be living on borrowed time running like this.
Edited by Dave T-S, 05 August 2003 - 10:45 AM.
#45
Posted 05 August 2003 - 10:51 AM
#46
Posted 05 August 2003 - 10:58 AM
#47
Posted 05 August 2003 - 10:59 AM
I run mine on Otimax and Millers Octane booster, I can't say I can feel any huge difference but I'm happier kowing a high octane is runing through it.how about running it on optimax?
does anyone know if the extra octane will help?
cheers
d
#48
Posted 05 August 2003 - 11:18 AM
Edited by Ricky2772, 05 August 2003 - 11:19 AM.
#49
Posted 05 August 2003 - 12:30 PM
Edited by Dave T-S, 05 August 2003 - 12:35 PM.
#50
Posted 05 August 2003 - 12:49 PM
#51
Posted 05 August 2003 - 12:54 PM
I guess the cooler running Iridium plugs would be advantagous. There was a long thread about this a month or so back. Since there is more heat from the increase in oxygen I suppose cooler plugs are the way to go.A question for all you techis out there, if the car is running lean would a plug change help & if so should it be hotter or cooler.
#52
Posted 05 August 2003 - 01:12 PM
Absolutely not!
The problem with running lean is there is too much air, or too little fuel in the mixture. You either need to reduce the air going in, or as is more usual get more fuel in!
The plug temperature range is only relative to the *correct* fuel mix. It is true a rich charge is likely to require a hotter running plug and a lean charge a cooler running one. Just because a particular engine is running lean (and therefore almost certainly hotter combustion chamber temps than usual) the correct way to deal with this is to richen the mixture, not change to a cooler plug - this is dealing with the symptom, not the cause.
Edited by Dave T-S, 05 August 2003 - 01:16 PM.
#53
Posted 05 August 2003 - 02:00 PM
#54
Posted 05 August 2003 - 02:07 PM
#55
Posted 05 August 2003 - 02:20 PM
#56
Posted 05 August 2003 - 02:26 PM
#57
Posted 05 August 2003 - 02:29 PM
#58
Posted 05 August 2003 - 02:35 PM
#59
Posted 05 August 2003 - 02:50 PM
Edited by Dave T-S, 05 August 2003 - 02:51 PM.
#60
Posted 05 August 2003 - 03:34 PM
