Nitrons & Na
Posted 08 August 2003 - 11:05 AM
Posted 08 August 2003 - 11:11 AM
Posted 08 August 2003 - 11:26 AM
Actually they should fit on both, VXT springs will fit directly onto an NA.Oh, just read some older threads, and it looks as though the VXT & NA run on differenct rear subframes, so they aren't interchangable
Nitron are looking to fit a set to an NA soon (we need a donor car, it'll still cost the £850 plus VAT but you get to be involved with it all) there shouldn't be any issue with the fitting or trnasference. The different subrames equate to the diff engine mounts the subsequent suspension mounts are identical.
Posted 08 August 2003 - 12:15 PM
Thorney,Nitron are looking to fit a set to an NA soon (we need a donor car, it'll still cost the £850 plus VAT but you get to be involved with it all) there shouldn't be any issue with the fitting or trnasference. The different subrames equate to the diff engine mounts the subsequent suspension mounts are identical.
Am very interested in this but would need to chat to someone about the ride quality after the Nitrons are fitted to ensure they're going to deliver what I'm looking for.
Especially if it's costing me £850 plus VAT
Jim
Posted 08 August 2003 - 01:04 PM
I got your PM, I'll send you an email.Thorney,Nitron are looking to fit a set to an NA soon (we need a donor car, it'll still cost the £850 plus VAT but you get to be involved with it all) there shouldn't be any issue with the fitting or trnasference. The different subrames equate to the diff engine mounts the subsequent suspension mounts are identical.
Jim
The thing everyone has to consider is that harder suspension DOES NOT mean it has to be a harder ride.
Suspension is part springs and part oil damping. When you get that crash/thump from a pothole it is a combination of the spring compressing either too fast or not enough and the oil damping not reacting fast enough/controlling compression enough - one cannot work well without the other.
Its for this reason that people just fitting harder springs or lowered springs to their car tend to screw the ride immediately.
The Nitrons come with harder springs but fully adjustable damping, thus far I've had mine set at 1 click - downright relaxed to 17 clicks - cyropractors dream the spring is harder but its the damping which regulates when and how that spring comes into affect. Think of it this way (albeit massively simplified) the spring holds the car out of the mud, the damping decides how far it has to go to drink it. and how fast it gets there.
Posted 08 August 2003 - 01:13 PM
Excellent news!Actually they should fit on both, VXT springs will fit directly onto an NA.Oh, just read some older threads, and it looks as though the VXT & NA run on differenct rear subframes, so they aren't interchangable
When is soon? An overhall of the suspension will be in order at some point soon, but I need to pay for a holiday & stuff firstNitron are looking to fit a set to an NA soon (we need a donor car, it'll still cost the £850 plus VAT but you get to be involved with it all)
Where are Nitron based in the UK?
cheers
Posted 08 August 2003 - 01:23 PM
That is EXACTLY what I'm looking for.The thing everyone has to consider is that harder suspension DOES NOT mean it has to be a harder ride.
John, I'll await your email.
