Alignment & Track
Posted 28 August 2003 - 01:36 PM
Posted 30 August 2003 - 09:13 PM
Posted 30 August 2003 - 09:39 PM
Posted 31 August 2003 - 08:34 AM
Posted 31 August 2003 - 09:16 AM
so this is what "scared stiff" fo in the UK?mmmmm....they look like this, /---\ (seen from front-rear)
How about a "How to remove your shims" guide Ricky?? Is this ok for road use?
Posted 31 August 2003 - 11:42 AM
that must be it, can't see what other mods could they come up with....so this is what "scared stiff" fo in the UK?
easy job, 2 big allen bolts behind the hub to loosen up, need only to fully remove one though.....(as it can be seen in the pic....)
slide out the desired amounts of shims, then test-drive it....
beware that modding the camber usually requires modding the toe as well....
more camber makes the front-end bite the turns better, so it might surprise the unexperienced with too sudden, understeer-free turn-in....that is why you want to open the front toe a bit to soften the steering input.... along the same line, closing the rear toe will add some stability to the rear-end, making it less jumpy and unpredictable...
just like for the pads replacement, this is something that is not to be done by wanna-be do-it-yourselfer, if you cock-up or forget to tighten up something it might lead to disaterous consequences.... :ph34r:
as a side note, the Opel monkeys proved once more their unparalled ineptitude, when reinstalling the rear hub after fixing the gear leak....while doing so, they overtightened the two allen bolts, even ruining the inside pattern, so when I tried to undo'em to change the camber they where soon hopelessly rounded....
....had to resort to a local mechanic to get'em loose...he had to sweat and curse for more than an hour, only to find out that those idiots used threadlock fluid on'em!!!
Edited by Ricky2772, 31 August 2003 - 11:45 AM.
Posted 01 September 2003 - 09:16 PM
Posted 02 September 2003 - 08:05 AM
Posted 02 September 2003 - 11:45 AM
cannot help in that, I was always advised not to mess with caster....it has to do with the angle between the hub and the susp. arms....not easy to fully understand....A few questions if I may: -
How do you change the castor angle? What effects does that have?
unless dealing with a racing car, working on camber and toe alone takes care of 99% of driving needs....
Posted 02 September 2003 - 12:21 PM
Posted 02 September 2003 - 12:45 PM
Posted 02 September 2003 - 02:22 PM
Posted 02 September 2003 - 02:23 PM
Posted 02 September 2003 - 02:24 PM
Posted 02 September 2003 - 02:29 PM
http://www.miata.net/garage/align.html
and
http://www.hummingbi.../alignment.html
But still no number.......
Posted 02 September 2003 - 03:09 PM
Posted 02 September 2003 - 06:06 PM
Posted 04 September 2003 - 04:39 PM
Posted 08 October 2003 - 11:06 AM
Posted 08 October 2003 - 12:14 PM
