Brake And Disk Replacement
#21
Posted 06 October 2009 - 07:17 PM
#22
Posted 18 March 2010 - 08:55 PM
#23
Posted 18 March 2010 - 10:03 PM
@ this guide. Just fitted new discs and pads this afternoon
Damn you Mr P4cks.... And your cheap cheap discs!!!!!
Though mine are scheduled to arrive tomorrow (every fcuking finger and toe crossed at the moment - and it bloody hurts) so should be able to fit them on Saturday with the help of redvts, subject to him still being available!
Oh and if anyone in the Newcastle / Gateshead / Durham or other NE area is considering doing it themselves (again if redvts doesn't mind) you are welcome to come and observe.... PM me and I'll send you the address and my contact details.
The fun should begin at 10am somewhere within the fair city of Newcastle upon Tyne. Though I know my luck and one of the calipers will just fall to pieces in my hand - Just a good job she won't need the other car next week if it does end up in disaster.
#24
Posted 19 March 2010 - 05:31 PM
#25
Posted 20 March 2010 - 04:04 PM
I'd help if redvts can't. Just let me know, it's a 30 minute job each side
Not in the rain, or on my car with discs that appeared to be 63k miles / 8yrs old eh?
But all done thanks to Darren (RedVTS) and 'The Doctor' (P4cks - once you had arrived
Next set of pads are definitely are going to be done with discs as for the minimal extra effort and cost (once we had knocked lumps out of them trying to get them to come off the hub) it seems to be worth it....
Time to go bed them in!
#26
Posted 21 March 2010 - 09:16 PM
#27
Posted 21 March 2010 - 09:45 PM
Edited by p4cks, 21 March 2010 - 09:48 PM.
#28
Posted 13 June 2010 - 12:26 PM
#29
Posted 22 April 2013 - 10:39 AM
#30
Posted 22 April 2013 - 01:25 PM
Nice one. Used it to fit my ally discs and bells last week as well.Thanks for the guide.
Just fitted ally bells/discs.
Took the tip to use an impact driver on the 5mm grub screw, worked a treat, not rounded and remove nicely. Not refitted as the bells don't have the hole.
Ally Bells/Discs = 5.3kg where as OEM discs = 7.1kg
#31
Posted 10 May 2013 - 01:08 PM
great stuff thanks for the pdfs.
#32
Posted 01 October 2014 - 07:57 AM
Dave If you mean a torque for reattaching the calipers then I couldn't find one on the TIS. I did mine up to just over 45 Nm which felt tight enough.
Is this the accepted wisdom?
Thanks
#33
Posted 01 October 2014 - 08:11 AM
If Rob suggests something I would be very very inclined to accept it as more than appropriate.Is this the accepted wisdom? ThanksDave If you mean a torque for reattaching the calipers then I couldn't find one on the TIS. I did mine up to just over 45 Nm which felt tight enough.
#34
Posted 01 October 2014 - 11:05 AM
you don't have to remove the rear calipers to change the disc / pads
just remove the outer and inner pads by pushing them to the centre , then you have enough clearance to remove the disc.
so no messing about with hand brake cable , no disturbing any safety critical bolts , no chance of damaging the boots.
#35
Posted 01 October 2014 - 12:09 PM
There was no chance of me managing that when I did mine, as the clearance was just too tight to squeeze pads back in. I found it much much easier to remove the caliper.
#36
Posted 01 October 2014 - 12:16 PM
you have to pull the brake caliper on its slider away from the car , then you have lots of space. you will have to wind in the piston.
#37
Posted 02 October 2014 - 07:35 AM
Thanks guys will have a good read at this and the TIS before I get on with the job.
#38
Posted 02 October 2014 - 10:12 AM
just watch this:
#39
Posted 17 December 2014 - 11:01 AM
Thanks!! Just what I needed right now.
Bing (1)
