Na Exhaust Diameter
Posted 25 February 2006 - 06:54 AM
Posted 25 February 2006 - 08:53 AM
Posted 25 February 2006 - 09:31 AM
Posted 25 February 2006 - 10:08 AM
However the calculation is not too easy, since it involves pressure drops etc....Basically, you should calculate the flow at your top rpm, and then select the diameter for the primary tubing. After that you simply multiply that value with 1.75...
Posted 25 February 2006 - 08:28 PM
Yup, I also found that article a while ago.However the calculation is not too easy, since it involves pressure drops etc....Basically, you should calculate the flow at your top rpm, and then select the diameter for the primary tubing. After that you simply multiply that value with 1.75...
What I've also seen is that a lot of the time the bore of the exhaust is upped somewhere around the 200bph mark. People usually seem to go to 2.25" or 2.5" exhaust systems. You see the same with the system on the turbo, that is 2.5" if I am correct. But ofcourse, that is a turbo, so it's a different story.
What might be an interesting combination is the milltek turbo damper on a 2.2 engine with a custom downpipe. So you would only need a bigger bore downpipe and an other main cat, cause the damper for the turbo is 2.5". Would be interesting to see if it makes a difference on a more tuned NA (compressor or maybe the TB's).
Mark
Posted 26 February 2006 - 08:33 AM
Posted 26 February 2006 - 08:58 AM
Posted 27 February 2006 - 12:18 PM
Count me in as an interested party please - maximising the flow from manifold to rear Miltek pleaseIf there was enough interest I'm happy to sort a cat bypass for the NA if people wanted?
Posted 23 March 2017 - 05:38 AM
I have a bog standard NA and I'm looking for all the standard NA engine specs that I can enter into the exhaust calculators
The different calculators ask for different specs with the usual BBDC. ATDC, overlap degrees etc
It's a bit like reinventing the wheel but I like the maths, sad, hoping to come up with a decent 4-2-1 system
Posted 23 March 2017 - 06:37 AM
Posted 23 March 2017 - 12:41 PM
Posted 23 March 2017 - 05:22 PM
this was my attempt at making a decent 4-2-1 looped system, and it works great
271 BHP and 213 ft lb of torque - normally aspirated
Posted 23 March 2017 - 05:27 PM
But very far from a run of the mill 2.2 though.271 BHP and 213 ft lb of torque - normally aspirated
Posted 23 March 2017 - 05:41 PM
it's all from the exhaust, honestly
Posted 23 March 2017 - 07:56 PM
Brilliant I'll have one of those Vocky, well something made locally as close as possible, maybe it'll give 4 BHP
I've read that the 2.4 intake is the way to go, but I've got a lot of homework to do with the remapping and where the sensors go etc
I can't find any detailed info on the stock NA specs, anyone know where I can find it, I like playing with calculations
Hope to get it on a track next month, can't wait.
Posted 23 March 2017 - 08:05 PM
it gives about 20 ft lb more torque than a 4-1 good quality aftermarket exhaust system
standard NA specs are quite poor, the engine was restricted to get the 145 bhp. Cams are only 244 degree.
The z22se also loves 11:1 CR with NA tuning, also do the balancer delete and open up the exhaust ports
Z22yh pistons and rods are a straight swap and will give you 11:1 CR or simply skim 1mm off the head
Posted 23 March 2017 - 08:50 PM
Trying to work out from your photo where the loops go underneath
It looks like you've paired 1+4, and 2+3 primaries. Oakmere above mentions a 1+3 and 2+4 system which seems to tie in with the 1,3,4,2 firing
Posted 23 March 2017 - 09:06 PM
most manifolds are paired 1+4 and 2+3, it creates the exhaust pulses which keeps the flow moving though the 4-2-1 manifold. 3 pulls 1, 1 pulls 4, 4 pulls 2, 2 pulls 3, etc, etc
Posted 23 March 2017 - 09:34 PM
Nice one thanks Vocky, great system you've got there, is that a Cat2 after the U bend.
The pre a post sensors are so close to each other did you have any dramas with that
