Rolling Road Power Figures
#61 Guest_Bletch (Guest)
Posted 14 May 2006 - 06:18 PM
#62
Posted 14 May 2006 - 07:16 PM
But, the key thing to take from a rolling road session like this is the relative figures. i.e. The figure before and after your modification or a direct comparison (preferably on the same day) of two cars on the same RR.
(The only other thing is to use the RR to set up your fuel pressure regulator so that you are achieving the bost O2 curve - if you have a variable FPR and I don't know how much difference that would make with the Vauxhall engines)
I agree 100% with John's posting and full credit to him for the honesty and telling people the facts as opposed to telling them what they want to hear. That's not to say that other tuners are being econimical with the truth... they're just reporting what their RR tells them - and most will only have access to a RR with non-VX specific transmission loss figures put in.
At the end of the day a RR session will give you hard relative "facts" about an engine mod. As important are the drivability and personal preference aspects of each and every mod.
Having said all that... I can wait to get up there and see my graph to analyse it to death!!!
P.
ps. John, when you going to sort your avatat out?!?
#63
Posted 14 May 2006 - 09:18 PM
#64
Posted 14 May 2006 - 09:37 PM
#65
Posted 14 May 2006 - 09:51 PM
#66
Posted 14 May 2006 - 09:59 PM
I, just like others mentioned have seen this problem before with different cars/bikesThe fact that your graphs on your website are so smooth and mine are kind of lumpy and lower on power overall makes you wounder as too what other factors would be causing the problem, as up to approx 3000 rpm mine are actaully better than yours It just goes wrong there after
PS can I have a free hybrid turbo replacement
You could line up five identical cars fit all the same mods and three out of the five will be pushing out different figures.
Its expect 'coz every car has slightly different tolerances, even the way it was first 'run in' can make a difference.
Its not your fault Steve or anyone elses that you got a dog
[sits back smugly knowing your the other side of the bridge ]
Edited by R1CHY, 14 May 2006 - 10:16 PM.
#67
Posted 15 May 2006 - 06:05 AM
#68
Posted 15 May 2006 - 08:30 AM
#69
Posted 15 May 2006 - 09:24 AM
BP = Barometric Pressure ( e.g. 1018 mbar )how do you know what the temps where?
what are the readings at the bottom of the graph? BP/RH/AT/IT/RR/TN?
RH = Relative Humidity ( % )
AT = Air temp ( 'C )
IT = Intake temp ( 'C )
RR = ?
TN = ?
These are my guesses.
#70
Posted 15 May 2006 - 09:33 AM
#71
Posted 15 May 2006 - 09:38 AM
#72
Posted 15 May 2006 - 09:48 AM
Good to see you all there, what a day!3. We did 3 standard NA's to stage 1 tunes and all three owners came back confirming the car felt stronger in every gear, acceprated faster, was smoother and had more torque. However on the rollers the gains on the chart were negligable. This I am looking into as it does seem odd.
Mine was one of the NA's remapped, although not expecting a great deal of an uplift, there was virtually none. At this point in the day I was questioning the departure of my hard earned!
I then drove it and although there wasn't an uplift in performance as such, the car did feel massively smoother (particularly sat in traffic this morning, it's normally really lumpy at low revs in the daily commute), everything felt torquier and moving the rev limiter up definitely has a excellent effect on the fun factor!
If John does however manage to eek out a few more ponies through reworking the maps though I'll certainly be interested to see what happens.
Dubious as to how much of this is due to the placebo effect as I was expecting uplifts and looking for them, however the car now feels how I would imagine that it should have done coming out of the factory and money well spent!
For the record (from memory):
Standard - 121.1 bhp (at wheels)
Stage 1 remap - 121.7 bhp
#73
Posted 15 May 2006 - 09:52 AM
#74
Posted 15 May 2006 - 10:02 AM
#75
Posted 15 May 2006 - 10:14 AM
Oi R1CHY get back too being a power rangerIts not your fault Steve or anyone elses that you got a dog
Just for the record when John re-mapped it and drove it he actually said that I had a good one.
I have got to agree with him.
Even though I have noticed this power dip (see pictures) it only seems to appear when you drive a certain way or is it due to lower amounts of petrol onboard . I had less than a quater of a tank when the test was done, and filled up and drove home and no problem.
#76
Posted 15 May 2006 - 10:43 AM
is that 2 pics from before and after a remap?Oi R1CHY get back too being a power rangerIts not your fault Steve or anyone elses that you got a dog
#77
Posted 15 May 2006 - 10:58 AM
#78
Posted 15 May 2006 - 11:03 AM
#79
Posted 15 May 2006 - 11:16 AM
#80
Posted 15 May 2006 - 11:17 AM
