Itg For Turbo?
28 replies to this topic
#21 P11 COV
P11 COV
  • 7,686 posts
Posted 08 June 2006 - 08:56 PM
Paul, how have you fitted the inlet pipe with your BMC. Is it pointing downwards and away from the intake grille? I've got a BMC airbox to fit in mine (I've relocated the ECUs onto the bulkhead behind the passenger seat and the standard airbox won't fit in place now). I planned to minimise the effect of water getting in by placing the pipe vertically downwards, and possibly blocking off the lower sections of the intake grille. I had a BMC on my turbo for a few months when I forst got it, without any problems, but it was dry for the whole time.
I'm on my fourth AMM anyway, so if I can get away with only 1 failure per year I'd be reasonably happy.
I had it pointed towards the air intake. And Joe.....I use the car every day whatever the weather.
#22 walkes
walkes
    for one night only, live at the appollo
  • 3,903 posts
Posted 09 June 2006 - 09:24 AM
/Thinking out loud Could the increase in air mass/flow be causing the AMM too fail. Do these not produce a higher and higher voltage for the increase mass/flow. Would it not be worth while placing something in front of the said intake to decrease the flow and record the voltage coming from the AMM? Not sure at what point the AMM would blow?
#23 walkes
walkes
  • 3,903 posts
Posted 22 June 2006 - 10:04 AM
Any sparkies out there able to try this ?
#24 paulf-cam
paulf-cam
  • 1,186 posts
Posted 22 June 2006 - 12:37 PM
/Thinking out loud
This is bonkers, isn't it? :) What happens when you get a remap and up the boost? Surely the airflow rate is increased? If that was the cause, then remaps would break AMMs too! :beat:
Ta, Paul.
#25 garyk220
garyk220
  • 3,035 posts
Posted 22 June 2006 - 04:27 PM
I'm fairly sure the failures are due to water ingress. I had the BMC filter on my car for a few weeks after running my car in, and somehow managed to avoid driving it in the rain for the best part of 4 weeks that summer, with no failure. I had 2 failures with a foam filter fitted. The first was at Hockenheim not long after driving on the autobahn in a torrential downpour, and the second was one 'summers' day up at Knockhill :rolleyes: Both times the foam filter was saturated, so it's reasonable to assume water droplets may have got as far as the hot wire in the AMM.
#26 walkes
walkes
  • 3,903 posts
Posted 23 June 2006 - 06:36 AM
So does this mean we are finally agreeing that it is water ingress that is casing the problem... ? Someone please investigate! P11COV would it not be worth posting pics of where you inlet pipe was
Edited by walkes, 23 June 2006 - 06:56 AM.
#27 davehutchinson
davehutchinson
  • 663 posts
Posted 25 June 2006 - 09:38 PM
Well the AMM failed on mine with no rain at all :/
#28 two4oneuk
two4oneuk
  • 731 posts
  • Interests:Cars
Posted 26 June 2006 - 10:30 AM
I fitted a new courtney panel filter (ebay) had read several posts about AMM failure but tried it anyway. The test was the same road ( dry day ) i use every day driving the same way and the EML came on within 10 miles. Swapped the filters back took car to dealer and he confirmmed the AMM had gone. Drove the car home and waited 2 days fro new AMM to arrive. Car now fine using standard paper filter and now having stage 3 + VXR turbo the car is pulling a lot more air in and drove 700 miles since saturday with no problems. Have a nearly new courtney filter for sale only used for 20 miles!!
#29 walkes
walkes
  • 3,903 posts
Posted 26 June 2006 - 01:49 PM
did you have a foam filter or Paper ?
