Apexi Power Intake
Posted 05 July 2006 - 12:45 PM
Check this out
Posted 05 July 2006 - 01:33 PM
Posted 05 July 2006 - 07:35 PM
Posted 05 July 2006 - 10:37 PM
The only way that filter could be so clean is to stop air entering the engine. even a hugly restrictive thick paper filter isn't that good and the best dual-layer, oiled foam filters are still no-where near it.
problem is without honesty you have no idea if it could affect the AMM on the turbo.
It could be a worthwhile upgrade... just don't expect it to be a perfect filter.
Posted 06 July 2006 - 09:39 AM
Posted 06 July 2006 - 09:54 AM
Just had a response back from a company for the cost....
Hi Steve,
Yes we can do a generic cone for £60.
Best Regards,
how cheap...
sounds good, did you ask them if it would be compatible with the vxt? suppose they're going to say yes whatever though anyway
Posted 06 July 2006 - 11:54 AM
Posted 06 July 2006 - 12:17 PM
Posted 06 July 2006 - 01:56 PM
Posted 06 July 2006 - 02:40 PM
Posted 06 July 2006 - 04:45 PM
Photo's please Cwnty
Posted 06 July 2006 - 07:45 PM
Posted 06 July 2006 - 08:06 PM
its gone a little off topic, but heres mine too
Posted 06 July 2006 - 08:11 PM
Posted 07 July 2006 - 07:05 AM
Posted 07 July 2006 - 08:54 AM
sorry didn't realise you ment for a VXT, however from what i've read in the post AMM failre is more being attributed to oil or moisture so this filter as long as shrouded from direct water ingress should be better than the others.
Don't all those cone filters come pre-oiled, making them a risk to the AMM?
Cheers, Paul.
Posted 07 July 2006 - 10:11 AM
Posted 07 July 2006 - 10:31 AM
Posted 07 July 2006 - 10:49 AM
I don't think this one is oil based, it is a dry filter, hence the questions...
Oops!
isnt it the extra airflow/pressure that causes problems with the MAF, not the oil ?
Absolutely not. Otherwise when you up the boost, you'd break it, no?
Cheers, Paul.
Posted 07 July 2006 - 01:13 PM
