Amd Vx220 Turbo Modifications
Posted 07 October 2003 - 04:30 PM
Posted 08 October 2003 - 08:22 AM
Posted 08 October 2003 - 09:24 AM
Posted 08 October 2003 - 11:46 AM
Posted 08 October 2003 - 12:00 PM
Loads okay for me!I click on the link & get to the page, but it doesn't load, just get left with a black screen with a white square in the middle.
Posted 10 October 2003 - 11:45 AM
Posted 10 October 2003 - 10:42 PM
It looks like their site has been flashed - looks good but could do with a SKIP INTRO link for us poor non-broadband people in the nethers of MK!By the way is it just me or is anyone else having probs getting onto AMD's site?
I was sure their site had some figures for possible power increases to the NA but now can't find them. Anyone any ideas?
cheers
Posted 10 October 2003 - 10:54 PM
Posted 12 October 2003 - 10:09 AM
the charge-cooler is definitely a trick setup. Can you give a bit more information on the testing/results that went into the kit ?
The old rule-of-thumb was that for every 2 or 3 degrees C the intake/charge temperature was lowered, you could get an extra 1bhp - plus stop the motor from risking a blow-up
I did post an item about the aquamist setup but nobody seems to be bothered in discussing the ins/outs of this line of thought in solving the same fundamental heat issues. Some people say it is very good at reducing in-cylinder temperatures, others say it also reduces charge temperatures (but to a lesser extent). Who do you believe ?!?
I did read some dyno figures based on a Vauxhall Cav. Turbo (C20LET engine) whilst the owner was playing with intake cooling hardware. The dyno printouts published told an interesting story :
(all on a standard engine)
standard car - 204bhp
air-water charge-cooler - 220bhp
large front mount intercooler - 239bhp
All with no other engine/boost mods - just goes to show the benefits of good intake temps !!
Read about it at http://www.a-bothie....ooler_info.html
When addressing the intake temp problem, did you try and get a larger capacity intercooler made, or is it a no-go like they must have assumed on the sprint ?
In your testing of the charge-cooler setup, what were the intake temps before/after and under road/track conditions with relation to the normal ambient air temps ? What's the trigger for the system, is the electric pump on with the ignition, or is it triggered by boost levels/temperature ?
If you want to label me as an obsessive pain then that's fine by me.. just want to know that a VX is for life , not just until the engine blows up
(I'm not a drive-in/chip it to the max/drive-out person either.. I like to know what they are actually doing)
Interestingly enough, Courtenay will now up the boost to generate 255bhp with no extra cooling so long as super + is used.. not sure I'd be happy running like that though, and I'm sure the high temps would soon make that power drop off even on the road.
Thanks,
Paul
Posted 13 October 2003 - 08:06 AM
The charge cooler was designed and built by a company that only makes charge coolers (primarily for race teams and high end sports cars). The system is 'live' all the time as the thermostat controls the temperature from going too low.Hi Thorney,
Thanks,
Paul
Aquamist kits are very good at reducing in cylinder temps (albeit very temporarily as the systems are designed really only to work when things get too hot) but have a much more limited effect in intake temps (although some effect is probable).
I've seen a load of data on the engine but in Astras, Vetras etc and to be frank ALL of this data is junk for us. The postion of the engine in the back of the car changes all the parameters for temperature and operating margin. Some tuners have simply assumed what works for the Astra must work for the VX and thats cobblers.
The intercooler is actually pretty good and doesn't need changing (especially with a CC), we could have gone bigger but the relative gains to cost wouldn't have been worth it, the CC does all the work now. The CC has a separate radiator fitted vertically to the front (so that it doesn't affect air flow to the main rad) so in effect the CC system is a completely separate cooling system for the car, only downside is weight - all wet it adds 10kg's but if that allows you to run 260-280bhp without issue then thats a small price to pay.
It is certainly possible to bolt on a chip and get an extra 50 bhp odd (assuming you have a Milltek or equivalent) but I had looong conversations with vauxhall on the heat issue and the bottom line is that this was a short cut to and engine blow. You might get lucky and it last months and months - but this is my personal car, so if I mod it how I want it it has to be as or even more reliable than how it was originally made - sadly that can't be cheap.
After watching AmD fit the system I'm actually quite surprised they agreed to my price suggestion (the deal was they benefit from me making my car available and being on hand for testing etc etc - invaluable to them, the other way if for them to buy a car) but they had to keep the price real and achievable.
To fit a CC, the front clam and side pod comes off. They then have to fit front rad, lead 1/4 pipe from this rad through the drivers side sill and up to the CC which is fitted to the right of the engine bay then pipe it all into the engine - a significant amount of work. As I know the cost price of the CC is a significant % of the overall cost I don't think AmD is making any profit on the CC on its own. This reflects its usage - the CC is ONLY there to allow you to run much higher power.
Posted 19 October 2003 - 01:46 PM
Posted 25 October 2003 - 08:00 AM
yep, I've been messing with a few and will post up the results.Thorney,
Have you changed camber angles since the suspension, I know you were looking in some new settings?
Posted 25 October 2003 - 09:10 AM
Posted 25 October 2003 - 11:58 AM
Posted 25 October 2003 - 09:33 PM
Posted 26 October 2003 - 07:31 AM
Posted 30 October 2003 - 04:51 PM
Posted 30 October 2003 - 05:38 PM
Posted 31 October 2003 - 07:20 AM
Posted 31 October 2003 - 09:01 AM
