Cooling Fan Running All The Time!
25 replies to this topic
#1 theotherhalf
theotherhalf
  • 249 posts
Posted 23 October 2006 - 05:49 PM
As of tonight :rolleyes: the cooling (radiator) fan on Elaine's Na starts as soon as you start the engine up no matter what the engine temp. I've: Checked the relay (not stuck) Reset the ECU (just in case) Checked the connections on the Coolant Temp Sensor (Nice & clean) Which I think really only leaves the Coolant Temp Sensor itself (?). Anybody got any thoughts on this? :unsure: Cheers Reg :)
#2 Astranomical102
Astranomical102
  • 614 posts
Posted 23 October 2006 - 07:05 PM
This hapened to me and got me worried as the fan and EML came on when the engine was cold. I bought an obd2 user interface of fleabay and downloaded carsoft from t'internet. It told me there was a fault with the MAF meter on the intake pipe, it turned out the wire was bare so i fixed it up cleaned it and clipped it back in. Since resetting the EML its been fine (rushes off to touch some wood) Not sure if this helps or not. Regards, Craig
#3 theotherhalf
theotherhalf
  • 249 posts
Posted 23 October 2006 - 07:22 PM
Cheers for the reply.
The EML isn't lit though................. :huh:
#4 theotherhalf
theotherhalf
  • 249 posts
Posted 24 October 2006 - 06:49 AM
Bit of an update, EML lit this morning, so I reset the ECU (again). Light not on now, but fan still runs all of the time. :rolleyes:
#5 Pidgeon
Pidgeon
  • 5,254 posts
Posted 24 October 2006 - 07:14 AM
Disconnect the coolant sensor wire. If fan stops, then sensor is cause.
#6 LMP1
LMP1
  • 247 posts
Posted 17 December 2014 - 12:18 AM
i have now the same problem. Do you have any update for that matter??
#7 The Batman
Posted 17 December 2014 - 12:28 AM
If sc then: Loom of doom Map sensor Intake temp sensor
#8 LMP1
LMP1
  • 247 posts
Posted 17 December 2014 - 12:30 AM
just the n/a
#9 The Batman
Loom of doom probably Get a code reader and see if you have a code Could also be second lambda
Edited by The Batman, 17 December 2014 - 12:31 AM.
#10 LMP1
LMP1
  • 247 posts
Posted 17 December 2014 - 12:34 AM
thanks. The weird thing is that it did it some time ago, then it stopped doing it and then today did it again... :huh:  :(
#11 ghand
ghand
    Drunken lampposts only
  • 9,215 posts
    Oh and more whisky
Posted 17 December 2014 - 02:20 AM
Mine does this from time to time and I just reset the fault code and all is well for months and months, you have a fault code latched up that puts the fans on but not the light, that's how it works for some reason. It is the air sensor. Think mine had done it three times in the last few years. Noisy them fans aren't they :lol:
#12 Rudy
Rudy
    ZZZzzzzz.....
  • 3,375 posts
Posted 17 December 2014 - 07:25 AM
Mine did this too. Changed sensor and no issues since. Congrats on the 8 year thread resurrection thumbsup
#13 CHILL Gone DUTCH
Posted 17 December 2014 - 08:41 AM
Second lambda caused this on mine Or a exhaust with a hole In it
#14 FLD
Posted 17 December 2014 - 09:03 AM
This.  Second lambda returning a lean reading will cause a P1171 code which doesn't light the eml but does trip the fan to run constantly.
#15 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
What chill said. Same happened to me.
#16 LMP1
LMP1
  • 247 posts
Posted 17 December 2014 - 09:51 AM
:lol:
did a search before posting and found this old thread so i said now there must be more experience
So i have to reset the fault and replace the second lambda
#17 FLD
Posted 17 December 2014 - 10:16 AM
Check the code first and check for exhaust leaks before you shell out on a new lambda.
#18 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 17 December 2014 - 11:17 AM
Happened on mine.  I had forgotten to re-connect the Intake temp sensor (grey thing on the intake pipe).  Just a normal N/A too
#19 slindborg
Posted 17 December 2014 - 12:04 PM
can also be the Eeeeeee geee arrrrrr valve too.
#20 Baron Von Scubadaddy
  • 6,644 posts
Posted 17 December 2014 - 02:08 PM
or unicorn poo in your intake temps
    Bing (1)
