Downforce And The Vxt
Posted 20 January 2007 - 06:36 PM
Posted 20 January 2007 - 10:23 PM
Posted 20 January 2007 - 10:45 PM
Posted 20 January 2007 - 10:56 PM
x-isle - I agree - not looking to chav up my car.
Just looking to optimise the car - got geo/ ohlins etc - but if the aero can be improved (especially getting downforce from under the car which doesn't involved introducing a load of drag which is often associated with big wings) then why not. Don't get me wrong I like the idea of a good looking diffuser, but they can be made to be functional as well - high end sports cars seem to manage this trick quite well. I would't stick a non-functional diffuser under my car.
Generally the car is producing lots of lift. All the add-ons (splitters, spoliers and diffusers) are there to reduce the amount of lift produced. Less lift implies that the car has more weight planted on the tarmac which equates to greater traction and hence a quicker laptime. I'm sure I've posted this before but it's hard to know what impact a diffuser has without testing. As you say, the aim is to reduce the amount of air under the car - hence the front spoliers and splitters.
Now if someone has access to a wind tunnel we could get the answer.
Edited by amrit, 20 January 2007 - 10:57 PM.
Posted 20 January 2007 - 11:04 PM
I dont think the VX produces masses of rear end lift.
I always thought the diffuser aided lateral cornering stability not downforce
I'm not sure one has ever been in a wind tunnel, although JT did extensive trackwork to test the wing/diffuser package from TMS
Posted 21 January 2007 - 02:00 PM
Posted 21 January 2007 - 02:16 PM
Posted 21 January 2007 - 03:20 PM
So the best option, rather than putting a wing on the back it to take off the roof, and enjoy the sunshine.
Not according to those figures it isn't!
Downforce Rear closed softtop:- 186 Nm
Downforce Rear open: -142 Nm
More downforce with soft-top on
Posted 21 January 2007 - 03:37 PM
No, you've misread it.
The figures are: rear downforce closed -186Nm (that's minus 186NM, i.e. 186Nm of lift ), which is reduced to -142NM of lift with the roof off.
But, of course, the drag increases when open, thus reducing topspeed.
The figures (in weight) for the VXT closed (again from Sport Auto measured at 200kmh) are:
Front 23kg downforce
Rear 19kg lift
In comparison, for the Exige S2, they measured:
Front 18kg downforce
Rear 26kg downforce – i.e. 45kg more downforce than the VXT
Edited by speedyK, 21 January 2007 - 03:38 PM.
Posted 21 January 2007 - 04:33 PM
Oh right, doh!
Lift rear closed: 186Nm
Similar kind of thing to saying "i was travelling down the road backwards doing -30mph"
Posted 21 January 2007 - 05:21 PM
I always thought the diffuser aided lateral cornering stability not downforce![]()
A diffuser creates down force on a car by creating an area of low pressure under the car effectivly sucking the car to the floor.
Posted 21 January 2007 - 07:24 PM
Posted 08 June 2007 - 05:18 PM
Posted 08 June 2007 - 08:06 PM
Posted 08 June 2007 - 08:12 PM
I've never had a look, has the VX got a flat floor?
Yes!
Posted 08 June 2007 - 08:18 PM
I second that
Posted 08 June 2007 - 09:11 PM
Posted 08 June 2007 - 09:30 PM
I hope nobody got hurt as a result of these although that seems unlikely given the damage!
Not much
>How NOT to do it<
>The end... and new beginning!<
– but enough to cause me to buy the Exige Cup
Thorney has played with diffusers, as did the racing team a couple of years back – try a search for diffuser.To get back to the subject of aerodynamics, () ideas?
Posted 08 June 2007 - 09:45 PM
Posted 08 June 2007 - 10:06 PM
