Can Anyone Tell Me What This Cable Conector Is For?
#21
Posted 29 August 2007 - 08:17 PM
#22
Posted 08 October 2016 - 05:26 PM
#23
Posted 08 October 2016 - 06:58 PM
no mystery about the two plugs;
if you have an early car with the Lotus engine loom then the post cat lambda sensor plugs into the single chassis loom plug.
if you have the later Vauxhall engine loom then the post cat lambda sensor plugs into the engine loom plug and the chassis loom plug is not used or connected.
Easiest method to tell the two looms apart - Vauxhall engine loom has the plastic tray above the injectors and the Lotus loom is wrapped with loom tape instead.
Edited by vocky, 08 October 2016 - 07:00 PM.
