Wheel Update
Posted 05 November 2003 - 08:47 PM
Posted 05 November 2003 - 10:17 PM
if you forget the emoticon, someone might believe you're serious...4. Get AO48's. They're fine in the wet
edited to say that they are indeed fine, ..... to CRAWL home if rain happens...
048's work IF at temperature....don't forget those "cuts" are purely for homologation reasons...when you say 048, think of slicks....
Edited by Ricky2772, 05 November 2003 - 10:26 PM.
Posted 05 November 2003 - 10:19 PM
Posted 05 November 2003 - 10:21 PM
afaik, superleggera's +048 save 3,2 kg each corner- I'll weigh them when I get a chance) the rotational weight is hugely reduced (just under 5kg's a corner)
changing to astra 4-bolts hubs requires to change discs AND AP calipers, or they can be kept?
Posted 05 November 2003 - 10:25 PM
The rear real news is the 16" front wheel. Now I'll be honest and did think Lotus using a 16" wheel was more marketing that purposeful - how wrong I was. I went from standard to new set up and turn in was sharper, steering quicker and whole car felt more alive - Now this could be due entirely to the lower weight of the wheel but I think the smaller size is crucial here.
Go for a 16" front - it does make a huge difference
I have a revived respect for Lotus, 16" front wheels aren't all hype, they do work I'm impressed.
Remember when you said how 17" fronts were right for VX/Speedster 'cos GM told you how it was "engineered" for them?
This confirms beyond doubt that it was really because Opel was insisting on 17" for marketing reasons – pandering to the ignorant masses to sell more. No skin off Lotus's nose either.
Glad to have this confirmation that 16" front is the way to go. Sure you're right about the lightweight hubs too. Just wondering if I can get this passed in Switz.
Is this right now:
Speedlines: 16" front, 17" rear with Lotus 4 bolt hubs and Yoko 048's fit with standard suspension and with lowered (no fouling anywhere).
And with race suspension (lowered) still not an issue at front or rear with the above kit?
Who's going to supply this stuff, AmD? Will official confirmation of suitability for fitting to VX/Speedster be issued (essential for Switz./Germany/Austria AFAIK)?
Did you get a chance to take some pics of this on the car, Thorney? Would be v. keen to see.
Posted 05 November 2003 - 10:27 PM
Posted 05 November 2003 - 10:32 PM
you saying that standard AP calipers that fit on 5-bolts hub, will ALSO fit on bog standard astra 4-bolts hubs? same 2-allen bolts caliper attachment?!?the discs have to change.....calipers are ok!
if so, that would be great news for you guys....
Posted 05 November 2003 - 10:37 PM
Posted 05 November 2003 - 10:47 PM
no available tyre size (like 225-50-16) in 048's and prolly in any other brand as well....is there some special reason why you can´t have 16" in the rear to?.
it would be cheaper and lighter.
...and they won't look good!
Posted 05 November 2003 - 10:54 PM
Can you roll GRP??? And I also thought that GRP was very difficult for the paint to bond too. Even when finished it is quite brittle...i spoke to regal today about the lotus wheels and they said they could flare the arches a tad so that they could fit.....
Posted 05 November 2003 - 11:27 PM
After looking again at the pictures of the Lotus OZs on paulb's car, they do look great. Do you know the offsets on these wheels?the discs have to change.....calipers are ok! i spoke to regal today about the lotus wheels and they said they could flare the arches a tad so that they could fit.....
PS Ricky, the calipers bolt to the uprights. Only the hub has to be replaced, the part the brake disc is bolted to.
Posted 06 November 2003 - 08:51 AM
Posted 06 November 2003 - 09:33 AM
Posted 06 November 2003 - 09:50 AM
Posted 06 November 2003 - 09:53 AM
Posted 06 November 2003 - 10:03 AM
Posted 06 November 2003 - 05:54 PM
Nearside rear sensor IIRCDoes decreasing the diameter alter the speedo/milage?? Or is that on the rears??
Posted 06 November 2003 - 06:13 PM
adopting the 195-50-16 front, there is the yoko 039 option... (exige standard rubber)Looking forward to new wheel options.
more an all-rounder, more cuts for better wet handling, and still decently sticky on dry.... I have a 50% worn out set in the garage, and I liked'em a lot....sure enough, I almost never drive in the wet, so 048 are the best choice for me...
039's will be discontinued soon, but for open-road usage and occasional trackdays, they are an excellent choice if adopting the front 16' inchers
Posted 07 November 2003 - 05:36 PM
Posted 07 November 2003 - 06:15 PM
