Abs Cut-off Switch
18 replies to this topic
#1 toreide
toreide
  • 315 posts
Posted 04 April 2007 - 09:06 PM
Fitted Toyo R888's yesterday. What a revelation. Huge improvement over stock as expected. The only drawback was the ABS giving me the hard pedal over very bumpy stuff.
Solution: Fit ABS cut-off switch.
I have read the various threads and guides, but as a noob I want to be on the safe side before I cut anything. As I have a left-hand drive Speedsters, layout seems opposite to the VX's.
My question is if take of the connector from the ABS ecu, expose the wires, pick the yellow wire I can see in there ( amongst a million others of various colours :blink: ), install switch - is this correct?
pic 1:
pic2:
#2 ChazUwe
ChazUwe
  • 2,450 posts
  • Interests:Cars, Computers, Drinking and travelling about.
Posted 04 April 2007 - 09:41 PM
Yes that is correct. I just used a spade connector on mine. Tracked on monday for the first time without ABS enabled and it really is so much better :) Obviously make sure you only connect/disconnect it with the ignition off :P
#3 toreide
toreide
  • 315 posts
Posted 04 April 2007 - 10:02 PM
Thanks!
#4 Muncher
Muncher
  • 4,494 posts
Posted 06 April 2007 - 12:52 AM
I am so annoyed with my ABS I'm going to fit another cutoff switch in the cabin and have it turned off in all dry weather.
#5 Gary Broad
Gary Broad
  • 21 posts
Posted 06 April 2007 - 01:51 AM
Had my ABS switch fitted by Plans while I was there having the geo sorted and can confirm positive results when switched off!
Seems to be worse when running harder suspension settings and hitting bumps when braking.
#6 Alex Os
Alex Os
  • 155 posts
Posted 06 April 2007 - 03:34 PM
I cut into one of the two wires which runs to the ABS fuse in the fuse box, got a toggle switch from Halfords(~£2-50), extended the wires by about 200mm, connected to the switch and then fitted the switch through a 1/2" hole which is already in the front crash structure just next to the fuse box. (Thanks Mr M) Really easy to do, only takes about 30mins. thumbsup
#7 Karlosfandango
Karlosfandango
  • 437 posts
Posted 07 April 2007 - 06:39 PM
Fitted one to mine yesterday after nearly binning it when the pedal went hard.
I followed the guide but used a key operated switch from Maplin.
I just routed the wires through the bulk heads and inside the dash. Took a little while but looks very tidy. I mounted the switch near the ingition as it's out of the way. As it is key operated I have the key on my bunch and it can then only be operated when the keys are out of the ignition, seems to work well.
Edited by Karlosfandango, 07 April 2007 - 06:39 PM.
#8 Muncher
Muncher
  • 4,494 posts
Posted 07 April 2007 - 10:15 PM
Good thinking Karlos, I think I'll be doing the same. I already have one under the bonnet but something like that would be much better. Do you have any pictures of where you put it and how you routed the wires?
#9 Karlosfandango
Karlosfandango
  • 437 posts
Posted 07 April 2007 - 11:52 PM
A quick list of how I done it.... -Solder two wires into switch and twist wires together for about 3 metres, then cover in insulation tape to form a loom. -Remove four screws around ignition cowl and pull apart. -Drill hole big enough to mount switch. -Remove dash fascia and remove stereo. -Mount switch (araldited the back nut aswell) and run wires up through behind heater and head unit. -Find gromit behind head unit and run wire through into footwell. -Find gromit into front compartment and run wires into it. -Tie wrap wire in place to keep it tidy. -Lay the loom up against the exposed yellow wire and cut the to suitable lengths. -Splice wires together by soldering and insulate. -Tie wrap all the pieces/wires back into place. To help pull the loom through the gromits I used a piece of solid copper wire used in house wiring. The pic won't show too much but I'll see if I can sort something out tomorrow thumbsup
#10 McFly
McFly
  • 23 posts
  • Interests:B-Roads, trackdays, etc.
Posted 15 April 2009 - 12:07 PM
pic1:
I'm about to do the same, but I've realized that the ABS connector has three yellow wires: a full yellow one, a yellow/black striped one and a yellow/grey striped one...which one should I cut? :unsure:
Edited by McFly, 15 April 2009 - 12:31 PM.
#11 bazzio
bazzio
  • 415 posts
Posted 15 April 2009 - 12:17 PM
:tumble: i thought taking out fuse 22 dose the job????
#12 The Batman
Posted 15 April 2009 - 12:20 PM
that disables the speedo :rolleyes: if you dont want to fit the switch then take out the front driverside abs switch
#13 McFly
McFly
  • 23 posts
Posted 15 April 2009 - 12:37 PM
Taking out the fuse or the ABS connector has the same side effects...the only way to go without problems is to cut the right wire and install a switch.
Please, anybody knows which wire should I cut from the ABS connector? The full yellow one, the yellow/black striped one or the yellow/grey striped one? :tumble:
#14 The Batman
Posted 15 April 2009 - 12:41 PM
it does do the same thing but will disable the speedo how ever taking the front driverside abs switch out disables the abs and keeps the speedo working
Edited by joe_589, 15 April 2009 - 12:42 PM.
#15 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 15 April 2009 - 12:58 PM
The solid yellow wire.
#16 McFly
McFly
  • 23 posts
Posted 15 April 2009 - 01:24 PM
Thank you!!! :rolleyes:
#17 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 15 April 2009 - 01:50 PM
it works just done it in 10 mins yellow wire it is spot on ouchie thumbsup
#18 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 15 April 2009 - 02:09 PM
Opps, I meant the brown/white wire.
Joking :lol:
I cut the wire a few inches along the loom from the ABS connector, relocated the towing hook and rubber grommet to the other side of the car, then installed a switch from maplins using the now vacant hole.
But I like the idea of having a key operated switch in the cabin so might try that sometime. The maplins key operated switch looks ok but I have managed to break the keys easily by being hamfisted.
Edited by Ouchie, 15 April 2009 - 02:15 PM.
#19 McFly
McFly
  • 23 posts
Posted 16 April 2009 - 07:06 AM
It's done! :groupjump:
Edited by McFly, 16 April 2009 - 07:07 AM.
