Edited by speedster, 07 June 2007 - 07:35 AM.
Cams
Posted 07 June 2007 - 07:34 AM
Posted 07 June 2007 - 07:43 AM
Posted 07 June 2007 - 07:45 AM
Posted 07 June 2007 - 07:53 AM
Posted 07 June 2007 - 08:50 AM
Posted 07 June 2007 - 09:00 AM
Posted 07 June 2007 - 09:18 AM
Don't the Shreks require some cylinder head work for fitment?Schrick one are certainly the most aggressive and powerful available ones for the moment
Posted 07 June 2007 - 10:16 AM
Posted 07 June 2007 - 10:22 AM
Posted 07 June 2007 - 10:47 AM
Thought you already had turbo cams from dude's engine?
Yup! I do. That's my SC build. Am looking for cam for my NA setup. Rather than destorying my NA I might be dropping the SC plant into a different chassis!
Posted 07 June 2007 - 11:04 AM
saab turbo cams are most likely standard cams, they might have a different sprocket to alter the timing slightly.
turbo's tend to use very mild cams due to valve overlap issues![]()
pipercams are cheap and work well, these are your own cams reground / metal sprayed.
schrick are double the price, these are new.
not much else available 'off the shelf'
Dude reckons the turbo cams are very close to standard but with a longer ramp
back to the NA...
Dbilas have the following cams
Duration: 264
Peak timing: 115/105
Valve lift: 10,8
Lift at TDC: 0,6/1,4
Valve timing (IO/IC - EO/EC) : 17/67 - 57/27
Piper are less aggressive
Duration : 260 deg
Inlet valve lift : .423"/10.74mm
Exhaust valve lift : .423"/10.74mm
Valve timing (IO/IC - EO/EC): 23-63/63-23
Inlet full lift (ATDC) : 110 deg
Exhaust full lift (BTDC) : 110 deg
Posted 07 June 2007 - 12:37 PM
if catcams make something for the z22se then id have that over any other cam maker.... they have awesome results in european racing.
Posted 07 June 2007 - 01:07 PM
Key
part #
duration [0.1mm+cl]
duration [1.0mm+cl]
maximum lift [cl=0]
lift at TDC [cl=0]
parts (followers retainers springs)
application
Cams
4603111
242 / 242°
206 / 206°
10.20 / 10.20mm
0.60 / 0.60mm
O.E.M.
HYDR: sport
4603112
253 / 253°
214 / 214°
10.50 / 10.50mm
0.90 / 0.90mm
O.E.M.
HYDR: sport
4603116
259 / 242°
222 / 206°
10.75 / 10.20mm
1.20 / 0.60mm
O.E.M.
HYDR: sport (turbo)
4603113
259 / 259°
222 / 222°
10.75 / 10.75mm
1.20 / 1.20mm
O.E.M.
HYDR: sport
4603114
267 / 267°
230 / 230°
10.75 / 10.75mm
1.80 / 1.80mm
O.E.M.
HYDR: rally & cross
4603115
277 / 277°
239 / 239°
10.75 / 10.75mm
2.50 / 2.50mm
O.E.M.
HYDR: rally & cross
4603251
286 / 286°
243 / 243°
11.60 / 11.60mm
2.80 / 2.80mm
custom
MECH: rally & cross
4603252
300 / 300°
252 / 252°
12.10 / 12.10mm
3.30 / 3.30mm
custom
MECH: rally & cross
4603253
306 / 306°
260 / 260°
12.10 / 12.10mm
3.85 / 3.85mm
custom
MECH: rally & cross
4603254
313 / 313°
268 / 268°
12.10 / 12.10mm
4.35 / 4.35mm
custom
MECH: rally & cross
Edited by speedster, 07 June 2007 - 01:08 PM.
Posted 07 June 2007 - 01:41 PM
Posted 07 June 2007 - 03:18 PM
Posted 07 June 2007 - 03:29 PM
http://www.moto-conc.../de/autos/opel/
http://www.mantapart.com/ecotec.html
http://www.courtenay....uk/default.htm
http://www.dbilas-dynamic.de/
http://www.imotecgmbh.de/
http://www.gozzoli.it/
http://www.vmox.de/html/z22se.html
http://www.pipercams.co.uk/
http://www.gmpartsdirect.com/
http://www.schrick.com/
http://www.kentcams.com/
http://www.catcams.be/
http://www.turbotech...&idproduct=2450
Also have all the cams from the above links in a list, which makes it easier to compare. Currently about 50 different cams...
Mark
Posted 07 June 2007 - 07:08 PM
From my notes list I have the following links to companies that seem to sell cams for the 2.2:
Mark
Posted 11 June 2007 - 09:31 AM
Posted 11 June 2007 - 10:37 AM
We use the Schrick ones (and stock em) but we're looking at different options on the race cars now and we want to go madder
Whats the spec on the Schricks? Got a spare flowed cylinder head lying around in TMS that you'd prep and dump a set in for me?
Any hints as to how madder your thinking of going?
Posted 11 June 2007 - 12:29 PM
