**low Coolant Light Came On Today**
13 replies to this topic
#1 l14mha
l14mha
  • 667 posts
Posted 10 June 2007 - 08:09 PM
i've never had a problem with coolant in the past. i was parked on a hill (nose up) and the red coolant light stayed on for 10 seconds or so. once i moved the car to a level section of the drive, it went off. yesterday i changed the oil and plugs. i checked the water and there didn't seem to be a problem. where are the most likley places for leaks or can water in the coolant system just evaporate?? thanks for the help. liam. :grouphug:
#2 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 10 June 2007 - 08:13 PM
Can you visibly tell that you've lost some? Common places would be the header tank (any small cracks around the connections, is it yellowing etc) the hoses either side of the radiator leaking, or the radiator itself, can you smell evaporating coolant all all :unsure:
#3 Mr Small
Mr Small
  • 474 posts
  • Interests:In no particular order....<br />Cars<br />Mountineering<br />Hiking<br />Cycling<br />Beer<br />Food <br />My Fiancee
Posted 10 June 2007 - 08:16 PM
is the sensor for the magnet in the bottom of the tank worked loose?
#4 l14mha
l14mha
  • 667 posts
Posted 10 June 2007 - 08:28 PM
it did seem a little low... i mean a fraction.
i have not checked the header tank closley, but it is not yellow.
i've checked the rad hoses and they seem to be holding pressure.
there is no water dripping ubder the car.
i'll double check the header tank tomorrow, maybe i'm just paranoid
liam
#5 slindborg
Posted 10 June 2007 - 08:57 PM
worth a read
http://www.vx220.org...showtopic=52514
but dont get paranoid.... easier said than done
#6 l14mha
l14mha
  • 667 posts
Posted 11 June 2007 - 05:55 AM
can some1 please confirm how high the water level should be in the header tank on a turbo... thanks.
#7 ianrm
ianrm
  • 11,097 posts
Posted 11 June 2007 - 07:35 AM
Normal level when cold is on the seam half way up the bottle. Light coming on could have been caused by parking on a slope and the float in the tank sticking.
#8 l14mha
l14mha
  • 667 posts
Posted 11 June 2007 - 08:13 AM
thanks ian.
do you think that it would be worth getting a pressure test done?
#9 Polanski
Polanski
  • 112 posts
Posted 11 June 2007 - 12:02 PM
HI - I got the same, apparently I need a new sensor, already on order. Don't believe it though but its free! Paul
#10 l14mha
l14mha
  • 667 posts
Posted 11 June 2007 - 12:04 PM
Paul
do you have a part number??
free?? how did you manage that??
#11 Polanski
Polanski
  • 112 posts
Posted 11 June 2007 - 06:00 PM
Sorry I asked VXL to look at it when last in and they ordered a sensor (under Network Q). Paul
#12 mandarinvx
mandarinvx
  • 12,621 posts
Posted 11 June 2007 - 07:29 PM
Shown here - item 17 thumbsup
#13 l14mha
l14mha
  • 667 posts
Posted 11 June 2007 - 07:31 PM
awsome, thank you chinky chinky
#14 johnaachen
johnaachen
  • 2,619 posts
  • Interests:Karting, F1, golf, tennis, binge drinking, giving up smoking
Posted 12 June 2007 - 07:27 AM
Mate.....the coolant light probably came on because you were parked uphill. If there was a sensor problem it wouldn't fix itself because you were now on flat ground - would it?! :P
