2.2 Fuel Pressure
#21
Posted 25 July 2007 - 12:36 PM
#22
Posted 25 July 2007 - 12:59 PM
can you do a pic of what hole in the throttle body its suposed to go to.
Thats what I'm stuck on; where the place to plug the hose in on the inlet manifold is... Why am I stuck at work when I want to be fiddling with the car
#23
Posted 25 July 2007 - 04:06 PM
#24
Posted 25 July 2007 - 04:09 PM
#25
Posted 25 July 2007 - 06:08 PM
#26
Posted 26 July 2007 - 12:48 PM
#27
Posted 26 July 2007 - 07:11 PM
#28
Posted 26 July 2007 - 07:53 PM
Not got the time unfortunatelycheaper at the scrappy
#29
Posted 31 July 2007 - 08:48 AM
Edited by andyroo, 31 July 2007 - 08:49 AM.
#30
Posted 31 July 2007 - 09:00 AM
#31
Posted 31 July 2007 - 10:20 AM
Any chance of any pictures?
Will see what I can do though
#32
Posted 31 July 2007 - 12:07 PM
its a real pita if you dont have hands like a 5 year old girl
Any chance of any pictures?![]()
chaz will be fine then!
#33
Posted 31 July 2007 - 12:35 PM
#34
Posted 31 July 2007 - 12:53 PM
Well I do have a 4 year old niece I could dangle over the engine bay. Maybe she can give the ITG a clean while she is there
Seriously, getting the nipple off was such a pita! You cant get a finger either side of it, and pliers or similar dont fit down the gap properly, I only just managed to pull it off without dropping it down into the abyss...
It still only took about 20 mins, but be prepared to loose some skin
#35
Posted 31 July 2007 - 02:51 PM
#36
Posted 31 July 2007 - 08:59 PM
So have you noticed a difference yet Andy? Im still amazed at how much quicker getting rid of the precat has made my NA feel. Must get round to this one soon.....
#37
Posted 01 August 2007 - 12:29 PM
have you got the vectra partno ? , im trying to think of an alternative hose
I havent got the part no. but if you print this diagram off and ask for part 36 from the Z22SE Vectra B, they should come up with the goods. Mine had to be ordered in. The pipe isnt straight like Vocky's one; its stepped, but still reaches fine. If anything the step moves it away fom the engine, which obviously, gets very hot.
Im expecting differences to start appearing as the ECU does its thing, but I have noticed one major difference; when lifting off the throttle at low engine speed, (ie 2krpm) I used to experience juddering, which I can only imagine was lack of fuel? Now, lifting off in the same situation, the engine smoothly drops in rpm, rather than juddering. In general, everything in lower revs seems a lot smoother.
Oh yeah, and my sports exhaust pops a bit more at low rpm when lifting off
#38
Posted 06 August 2007 - 09:02 PM
#39
Posted 07 August 2007 - 08:31 AM
bad:
The engine seems less happy - it doesn't start as easily as it did before, and i stalled it for the first time in a year(while pulling away from my house)
I have definitely lost power all over the rev range (probably due to the lack of an induction kit, but i don't believe that would help low-down torque)
WOT at very low revs seems to result in something that sounds like pinking
What is pinking and how can you tell its happening?
I have only had good results so far, everything above about 3krpm is the same, and below is smoother and more responsive. Pulling away is smoother (I can use less throttle too), idling is smoother. I get the same pull in 3rd at 30mph that I used to have to go to 2nd for. But then again, I do have an ITG...
Is it possible that you aren't getting enough oxygen and too much fuel?
#40
Posted 07 August 2007 - 09:01 AM
It's engine knocking and you can hear it (hence the name).What is pinking and how can you tell its happening?
