Soft Top Cable Replacement....
#21
Posted 04 August 2010 - 08:57 PM
#22
Posted 05 August 2010 - 08:21 AM
I had an absolute mare with mine the other week, one area had been stiched narrower than the rest and would if fcuk get past it. Never want to have to do that job again!!!
Yet to get the cable to do it, but does look a ridiculously tight fit - you'd think they'd have modded the roof over time to make it easier not harder, seeing as it's clearly something that every long-lived VX will need eventually. Can't be any easier for a Vaux mechanic to do.
#23
Posted 06 August 2010 - 10:59 AM
#24
Posted 14 October 2010 - 07:16 PM
#25
Posted 14 October 2010 - 07:19 PM
Ooh this subject comes round and round. Just been taking out my soft top thermal protection pack (toasty warm even with soft top) and thought to myself that the cable would benefit from being tightened.... Doh!
So I have had to create a temporary fix as it was the front one and didn't fancy it flapping around on the motorway up to Newcastle tomorrow. So choices, choices, do I go for the Eliz special or the Loti replacement (if they do one).
Hmmm?
pm sent
#26
Posted 14 October 2010 - 07:31 PM
Hmmm?
pm sent
PM received, cheers Fab
#27
Posted 03 April 2014 - 10:18 PM
Just replaced the rear cable on mine. There was no way the new cable (Elise parts) was going to pull through so I removed the line of stitching making the slot bigger. I then removed the eye with the adjuster, taped the barrel part of the adjuster to the cable and simply pushed it through.
It took me about 20 minutes in total
#28
Posted 04 April 2014 - 05:45 AM
#29
Posted 03 July 2016 - 01:28 PM
What an absolute pain of a job, and a reminder why I never do any jobs on this car if I can avoid them.
If you manage to get in the situation where you're pulling the old cable through and it detaches part way (because the stitching is so tight) just pull the old cable out completely. Snip the ends off if you have to.
Then get an old metal coat hanger, straighten it out, and being the right length and stiffness it will easily push all the way through the seam. You can then create a hook at the end using a pair of pliers and hook the end of the new cable on to it. Pull the new cable back through (smaller end is easiest).
#30
Posted 03 July 2016 - 08:00 PM
#31
Posted 04 July 2016 - 11:44 AM
Whoa! You did something other than polishing your car! Sent from my cuntyfuckbollock phone by Twatatalk
I would say never again, but I've also got a rear light with a reflector thats come off so thats next weekends annoying job.
You can imagine how much I'm looking forward to messing that job up at £300 a light!!
#32
Posted 04 July 2016 - 08:02 PM
Alternatively get the wife to do them. She did both of mine. The first by the pool in the South of France!
#33
Posted 12 August 2017 - 02:25 PM
I screwed the new cable onto the end of the old cable. Took a bit of tugging (ooh er) then went through dead easy.
Hardest part was undoing the screws, which were a bit stiff.
Took about 20 mins, but could probably repeat in about half that time.
#34
Posted 06 August 2018 - 11:15 AM
I'm about to tackle this job but there's no way I'm buggering about unstitching fabric then having to restitch it.
I'd have thought it would be easier to feed a length of 2mm coated stainless cable through and put the end fittings on with a press afterwards?
#35
Posted 08 August 2018 - 08:18 AM
attach the new cable to your old cable and pull through, a lot go through no problem, some are just stitched tighter than others
plus your suggestion about 'putting the end fittings on with a press afterwards', who has a press they can use?..... not many I imagine!
Hence why they are sent out made up, the crimps are put on with a 25 ton hydraulic press, not mole grips. they are made to last...
Hand spliced cable is nowhere near as strong as hydraulic-spliced cable and it won't slip like hand spliced..
