Tms Team Dynamics Pro Race 1.2
Posted 16 September 2007 - 05:18 PM
So if you have a spare set and fancy selling the fronts (perhaps your rears have shot it), I would be very interested.
£599
Developed directly between TMS and Rimstock, these are the only wheels in the world custom designed for the VX220 and Speedster. The front wheel has been designed with a 20mm offset to widen the front track a little and give better front end grip as well as providing ample clearance for the AP brake kits. Weighing in at only 7.3kg's the front wheel saves over 3kg's in weight over standard so turn in is far better. The 16" size lends itself to a wider choice of tyres including track tyres such as the Toyo R888 and the Yokohama AO48.
Posted 16 September 2007 - 05:26 PM
Posted 17 September 2007 - 04:26 AM
I'm sure John will sell you the fronts only if that's all you need
Alternatively, if you pop over to type116.com and look for details of their TD1.2 group buy, I'm pretty sure their supplier will be able to do fronts only too (and they can be in whatever offset you want).
HTH
Not in the 20mm offset they can't I'm afraid.
Posted 17 September 2007 - 10:16 AM
Strange I'm sure there are several people out there happily running 16" fronts with 20mm offsets sourced through this group buy - admittedly they're of the 'spigot ring' type though (and not sure if they're a smidge heavier too??). I'm sure someone else will be along in a minute to confirm or set me right
Edited by Mr_M, 17 September 2007 - 10:16 AM.
Posted 17 September 2007 - 11:47 AM
[quote name='Mr_M' post='640653' date='Sep 16 2007, 18:26 ']
I'm sure John will sell you the fronts only if that's all you need [/quote]
John
I don't suppose that you have a front set kicking around the back that are surplus? that you could sell me
If not how much to purchase a set of fronts only?
