[FONT=Impact]
I fitted the E-charger (see back a coupla pages) over the last few days. Quite complicated cos I fibreglassed the motor into the airbox rather than run it in the inlet trunking. Seats and trans tunnel had to come out for the wire runs. Had the first drive (in the wet) today. It certainly makes an interesting noise when it cuts in --seems to boost top end power but that's just a subjective feeling till I get it dynoed. Motor is a ducted axial flow turbine drawing 50 amps/700 watts and shifting 700 cfm at 22,000 revs. Its only rated for continuous use for max 15 secs so you wire it to cut in on full throttle only. Gains are claimed to be 4 - 6%. Theoretically producing a pound or so of manifold pressure should be a great improvement over fitting expensive inlet manifolds and fancy air filters which, at best, can only decrease manifold vacuum.
Griffo
E-charger Update
Started by
griffo
, Dec 21 2003 02:54 PM
1 reply to this topic
