Ap Racing Brakes?
#21
Posted 17 October 2007 - 12:23 PM
#22
Posted 17 October 2007 - 03:33 PM
#23
Posted 17 October 2007 - 03:37 PM
Quite impossible to agree with the percentages quoted. The reason for four (or more) pistons is as follows-
If the brake master cylinder has a cross section of A and the brake pistons have an area of A x 4, then four times the pressure you exert upon the pedal is exerted upon the disc. To increase the pressure, you need to increase the size of the pistons, but you soon reach the size limit of the piston inside the caliper and the caliper upon the disc. Moving to more smaller pistons allows a larger piston area and therefore more pressure.
However good your pads and discs, they are nothing without pressure
To suggest rotors will have any impact above a few percent is plain wrong. Ali-bells are good for unspring weight, but the pad is the wearing part of the brakes and unless you want very soft discs they will not impact upon the overall performance to any great degree.
You're comparing theory with practice....
Does the bigger discs necessitate any change to the calipers? I've had bigger discs which which required the caliper to be spaced out = bigger pivotal force = better braking.
#24
Posted 17 October 2007 - 04:03 PM
#25
Posted 17 October 2007 - 04:30 PM
Search for Hi Spec and all your questions will be clear.
I dont think the group buy went ahead in the end, I think there was quality control issues and no conversion to include the handbrake??
(Mechanical numpty as well
Andy
Edited for you as I have just read this
http://www.vx220.org...pic=48280&st=40
Andy
Edited by covert ops, 17 October 2007 - 04:40 PM.
#26
Posted 17 October 2007 - 04:42 PM
We'll have our own separate ali belled AP disk upgrade in stock soon, will be cheaper than Plans (although I disagree on the percentages quoted). We've got 100 sets coming in.
Woot need !
Hope they will be a bit lighter than my Eliseparts ali belled items too (5.6 Kg)
#27
Posted 17 October 2007 - 04:52 PM
Furby123
(Mechanical numpty as well)
Andy
Edited for you as I have just read this![]()
Andy
See what you mean about the hi spec jobbies - I think Ill stear clear of that make - what about a bigger vauxhall brake set up?
Hail to all mechanical numpties
#28
Posted 17 October 2007 - 04:59 PM
Furby123
Andy
Andy
This thread is about the front discs and calipers not the rear
However.
If you can run Pagid Rs14's on the front or indeed Ferodo DS2500 pads, preferably with 4 pot calipers, and Rs14's on the rear standard Brembo caliper, then this is all you need to achieve a decent balance or braking bias.
Jas
#29
Posted 18 October 2007 - 01:47 PM
#30
Posted 18 October 2007 - 02:30 PM
Furby123
Andy
Andy
This thread is about the front discs and calipers not the rear![]()
However.
Jas
Thanks Jas
(teach me not to speed read!!
But I think he got the idea
Andy
#31
Posted 18 October 2007 - 04:04 PM
I have a question.
I have fitted a set of the AP 4 pot calipers to my 2.2 VX but the wheel is very close to the wheel (about 1mm close). My VX has the Turbo wheels fitted is this the cause or should it be like this???
Please don't tell me I have to change my wheels.
yes, thats how they are supposed to be
#32
Posted 19 October 2007 - 10:54 AM
Furby123
Andy
Andy
However.
Jas
I always wonder how different can different makes of 4 pot calipers be?
So what makes the AP's so so expensive? Is it just the brand name? Or are they using vastly superior parts and fluid management techniques?
Edited by speedster, 19 October 2007 - 11:12 AM.
#33
Posted 19 October 2007 - 11:01 AM
Edited by jasvxt, 19 October 2007 - 11:01 AM.
