Hi,
I don't have a fortune to spend but Im looking for a way to improve grip on the standard tyres. Does anybody know if the AD07 fit into the standard rim and if they and provide sufficient grip for road use (i.e. fast mountain drive).
Easy And Cheap Way To Upgrade Tyres
Started by
calbee
, Jan 03 2004 02:18 AM
3 replies to this topic
Posted 03 January 2004 - 02:18 AM
Posted 04 January 2004 - 09:26 PM
The short answer is no i'm afraid. At least not on the front, which are a unique size. Only the Bridgestones fit, unless you get different front rims. Thorney and I both have Yokohama a048 tyres, standard size rear and 195 width 16's on the front. These are new Lotus Exige tyres available only through Lotus dealerships. They are similar to cut slicks, very grippy and road legal. For wheels I would suggest Speedline multi-spokes. Thorney is developing them and I believe they should be available in a month or so......not much else will fit. I have oz superleggeras but need to use special washers to make them fit. Hope this helps.
Posted 04 January 2004 - 09:35 PM
I think Cheeky Chops put some other tyres on.
Not much point doing anything during the winter IMO unless the you do not plan on using the car much.
Posted 05 January 2004 - 12:11 AM
Cheeky has got Bridgestones on iirc.
I've got Toyos on the rears. They seem to grip better in the dry but are worse in the wet.
