Does A 6 Speed Astra Box Fit A Vxt
5 replies to this topic
#1 tony1
tony1
  • 175 posts
Posted 06 December 2007 - 07:34 AM
:groupjump:
#2 rabidh
rabidh
  • 1,640 posts
Posted 06 December 2007 - 09:24 AM
:groupjump:
Vocky is going one with a Vectra box. It seems to involve quite a bit of work though.
http://www.vx220.org...showtopic=58746
I assume there is a reason the Vocky didn't use the Astra box though - but no idea what it is!
#3 SteveA
SteveA
  • 9,157 posts
Posted 06 December 2007 - 09:50 AM
Vocky is doing the vectra box because his engine is a Vectra engine, Z22SE. Turbo is an Astra engine Z20LET. Don't know if it would work tho.
#4 vocky
Posted 06 December 2007 - 10:11 AM
yes you can fit a six speed box to the vxT you need a M32 gearbox from a z20lel / z20ler / z20leh vehicle - either an Astra H or late model Zafira you will also require; driveshafts (£250 each) and a rear gearbox mounting (£140) from a 2007 Lotus Europa S a 'one off' clutch plate (£310 for an uprated kevlar clutch plate + cover) and the slave cylinder needs a spacer because the DMF (dual mass flywheel) is deeper than a solid flywheel OR you could just fit a DMF flywheel + clutch. the gear linkage needs modifying or you could buy the Lotus Europa S system for a mere £1100 :blink: not an easy conversion, but quite fun :lol:
#5 tony1
tony1
  • 175 posts
Posted 06 December 2007 - 07:25 PM
which drive shafts do i use.can i use the astra ones
#6 vocky
Posted 06 December 2007 - 07:35 PM
you should be able to use the astra H z20lel or z20ler (sri turbo) driveshafts, but the z20leh (vxr) do not fit. or just buy some new lotus europa S driveshafts
Edited by vocky, 06 December 2007 - 07:36 PM.
